Hit Windows + X and then press the arrow Up key a few times; does the relevant options highlight when you do?
I ask you to do this to make sure the Win-X menu is in focus. Because if it's not in focus, pressing letters will not work.
If you have a window open when you press Win-X, you should see it's top bar colour change as it's brought out of focus in favour of the win-x menu.
IF... If when you hit Win-X and it doesn't switch focus to the menu (as it should), there must be something misbehaving somewhere that is stealing focus.
Hang on though - and this may be me being dumb again - but isn't that normal behaviour? It certainly seems the same when I tried it.
* If I do Win-X I get underlined letters;
* If I hover lower left and right-click they aren't underlined, although if I press one of the keys that would have been underlined, they still work. For example {hover lower left} + {right click} then press {E} = File Explorer.
Here's what I found out - Win-X brings up the list of shortcuts and I CAN use the arrow to highlight the various options and then either hit enter or use the mouse to select it. I still CANNOT use the letter. Hovering my mouse in the lower left, R click to bring up the same options w/out the underlined letters, I am NOT able to press a letter as mentioned above. Does the arrow activity mean I'm close to getting resolved? Thanks.
By default, the underline shortcuts will still work regardless if you used Win+X or right click to open it. It's just that you only see them underlined with Win+X.
Were you able to do a system restore to before you had this issue?
Thank Medab1 and Brink! Brink - my only restore date I show is 1.21, but the issue happened before that, so that won't do much good sad to say. I'll see about calling that # too.
I tried this on a couple of different folders and files - there are no underlined letters, so this would not allow me to choose the option unless I clicked on it. I would expect that behavior, no?
Good idea, but if sticky keys is enabled and you attempt to press Windows-X the usual way by holding the Win key down, when you press X sticky keys will disable automatically, because it see's you're capable of pressing two keys at once.
One would have to change the sticky keys options from it's default to prevent it from disabling itself when more than one key is pressed.
I have a feeling that the presence (or lack) of underlines is a feature of the Windows 8 interface - if you are using mouse clicks, or taps, then the underlines are not displayed (because you are unlikely to need keyboard shortcuts), but if you use shortcut keystrokes to get to a menu, then the underlines are shown as an aide memoire. It is clever and part of the perfect typography philosophy that underlines the new design elements in Windows 8.
If the ability to use shortcut keystrokes is missing, then there is almost certainly some setting that can restore it either in the policy editor or directly in the registry - but of course, the registry is as full of mysteries as ever.
One thing that you may try is to enable the on-screen keyboard - :winkey:+U then Alt+K (or Mouse or Tab etc) - see if that tells your system there is a keyboard attached that can do shortcuts.
Mods (Thanks for including the "WinKey" :winkey: and the "Orb" start symbols in the smileys)
Here's what I found to work - Win-X to bring up the underlined letter options and Win-(letter of underlined shortcut) to actually bring up the desired result. This seems to be fine. Is that what we would expect or should we still expect just typing the letter? I'm fine w/the result I mentioned and it seems more consistent. Just my two cents.
