there's no need for all of this
When Windows is asking for driver, just click Cancel. You will be brought back to the welcome screen. At the welcome screen, remove your USB drive, insert it back to DIFFERENT USB PORT. Click Install Now again. The installation process will be like usual.
This problem happened to all new version of updated Windows 7 installer. I think, it is due to failure of Windows installer to remain its detection to the USB drive. It lost the connection, and became confused, don't know where to find the USB drive it used to read before.
When we re-insert the USB drive, Windows installer will detect the USB drive back, and continue like usual.
good luck guys
This is exactly what I do whenever that happens and it always worked.
I was about to post that, but I guess you did it first.
- Windows 8.1 Pro 64-bit
- CPU
- i5 4670K @3,4Ghz
- Motherboard
- MSI Z87-G45
- Memory
- Kingston HyperX Beast 8GB @1866Mhz
- Graphics Card(s)
- Sapphire R9 270 2Gb Dual-X
- Monitor(s) Displays
- 2x 19" LCD
- Screen Resolution
- 1440x900
