SFC and DISM problems
Ztruker
Space coast of Florida
Ran SFC /SCANNOW which found errors it could not fix.
Ran Dism /Online /Cleanup-Image /RestoreHealth and it failed with an error:
2014-02-21 21:31:48, Info DISM DISM Package Manager: PID=5744 TID=1860 Error in operation: source for package or file not found, ResolveSource() unsuccessful. (CBS HRESULT=0x800f081f) - CCbsConUIHandler::Error
2014-02-21 21:31:48, Error DISM DISM Package Manager: PID=5744 TID=3612 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x800f081f)
2014-02-21 21:31:48, Error DISM DISM Package Manager: PID=5744 TID=3612 The source files could not be found; their location must be specified using the /source option to restore the feature. - GetCbsErrorMsg
Attaching a SFCandDISM.zip which contains sfcdetails.txt which is the output of
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >sfcdetails.txt
and dism.log.
View attachment SFCandDISM.zip
Any suggestions on fixing these errors appreciated.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
Did you run it in elevated command prompt ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Try restarting & running dism first thing.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Or try Safe Mode with networking.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
I looked at your logs and there are 4 KBs that cannot be verified (eg, component hash failures); however, the bigger question is:
"What issue prompted you to run these commands in the first place?"
Once the real issue is known, then maybe the failures will make more sense.
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
Very good point. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
No issue. I was looking at another thread about creating a batch file to run SFC and DISM so thought I would try it. Both shouldn't cause a problem and should run successfully.
I'll try the suggestions and see what happens.
I have UAC fully disabled but will try DISM from a Elevated Command Prompt and Safe Mode. Thanks.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
I saw linked post on another site and though it might be helpful. There are some options I was not aware of if you use the command below to get help on that subject.
DISM.exe /Online /Cleanup-Image /?
Dism online restore health function gets error 0x80240021 - Microsoft Community
Maybe start with the command below to see if it shows anything..
DISM.exe /Online /Cleanup-Image /AnalyzeComponentStore
    Windows 8.1 x64
    Home Grown
    i7 3770K
    ASUS P8Z77 -v Pro, Z87-Expert
    16 G
    EVGA GTX 680 Classified (2)
    Kingston SSD 240 GB
Dism /Online /Cleanup-Image /StartComponentCleanup should partially resolve the issue. You'll also need to run sfc again. Make sure that the PendingDeletes and PendingRenames folders exist under %WinDir%\WinSxS\Temp.
The attached file is a scripted version of all the commands.
  • DISM.bat
    Windows 8.1 Enterprise
No help :(
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
I'm anal, this would drive me nuts also.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
I've already looked at the google responses, thanks.
From what I'm reading, the fix is to reinstall Windows 8, which I'm not about to do as it runs great. I'll live with it.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
Output of SystemLook (64 bit):
SystemLook 30.07.11 by jpshortstuff
Log created at 19:30 on 23/02/2014 by rrkurtz
Administrator - Elevation successful
========== filefind ==========
Searching for "luainstall.dll"
C:\ESD\Windows\sources\luainstall.dll --a---- 50176 bytes [04:50 30/09/2013] [09:53 22/08/2013] FFFF498E680E92052683AAFDFAE4D981
C:\Windows\SoftwareDistribution\Download\bbcd2cf9b320a453d034b77497ec5af5\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_62280e15510f8e79\luainstall.dll --a---- 50176 bytes [02:30 22/02/2014] [04:21 10/11/2012] FFF365F8805100FDB2A0789723A15FBF
C:\Windows\System32\luainstall.dll --a---- 50176 bytes [01:55 26/07/2012] [03:06 26/07/2012] F257056A1044B31F6FE9C67E393ED558
C:\Windows\SysWOW64\luainstall.dll --a---- 39424 bytes [02:01 26/07/2012] [03:18 26/07/2012] 902B161E360563DED4F3099C55062411
C:\Windows\WinSxS\amd64_microsoft-windows-luainstaller_31bf3856ad364e35_6.2.9200.16384_none_718018daf20f86f3\luainstall.dll --a---- 50176 bytes [01:55 26/07/2012] [03:06 26/07/2012] F257056A1044B31F6FE9C67E393ED558
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16384_none_622908ad510eb05b\luainstall.dll --a---- 510 bytes [05:28 26/07/2012] [21:22 26/12/2013] A4CDED4746E7597B1A7DF708087EE038
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16613_none_6273bd8950d6cae2\luainstall.dll --a---- 438 bytes [18:59 08/11/2013] [21:22 26/12/2013] 3174425FF50C71D1544504150C5FC1A9
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_62280e15510f8e79\luainstall.dll --a---- 50176 bytes [18:59 08/11/2013] [04:21 10/11/2012] FFF365F8805100FDB2A0789723A15FBF
C:\Windows\WinSxS\x86_microsoft-windows-luainstaller_31bf3856ad364e35_6.2.9200.16384_none_15617d5739b215bd\luainstall.dll --a---- 39424 bytes [02:01 26/07/2012] [03:18 26/07/2012] 902B161E360563DED4F3099C55062411
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16384_none_060a6d2998b13f25\luainstall.dll --a---- 506 bytes [05:28 26/07/2012] [19:52 27/12/2013] B270A12D3DA6D63058C0526CC6762013
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16613_none_06552205987959ac\luainstall.dll --a---- 433 bytes [18:59 08/11/2013] [19:52 27/12/2013] FBEEA251290B0A51F7F35E3BCD0FAC47
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_0609729198b21d43\luainstall.dll --a---- 39424 bytes [18:59 08/11/2013] [18:59 08/11/2013] 2F98BDD97F521458051F4C281C7B3CF2
Searching for "ntevt.dll"
C:\Windows\SoftwareDistribution\Download\842c98013e1decf29608fc1f0976e551\amd64_microsoft-windows-wmi-ntevent-provider_31bf3856ad364e35_6.2.9200.16384_none_492347b5369e9a83\ntevt.dll --a---- 239104 bytes [02:30 22/02/2014] [03:06 26/07/2012] 54EA7E89556AFF96362B62ED8CF2C6C2
C:\Windows\System32\wbem\ntevt.dll --a---- 239104 bytes [23:56 25/07/2012] [03:06 26/07/2012] 54EA7E89556AFF96362B62ED8CF2C6C2
C:\Windows\WinSxS\amd64_microsoft-windows-wmi-ntevent-provider_31bf3856ad364e35_6.2.9200.16384_none_492347b5369e9a83\ntevt.dll --a---- 239104 bytes [23:56 25/07/2012] [03:06 26/07/2012] 54EA7E89556AFF96362B62ED8CF2C6C2
Searching for "MpAsDesc.dll"
C:\Program Files\Windows Defender\MpAsDesc.dll --a---- 150688 bytes [18:48 08/11/2013] [18:48 08/11/2013] A1C2796F698474BAA1ABD5B80B3835C8
C:\Program Files (x86)\Windows Defender\MpAsDesc.dll --a---- 150688 bytes [18:48 08/11/2013] [18:48 08/11/2013] DCD1DD102072EFFD763BE1C43EA7E6B4
C:\Windows\WinSxS\amd64_windows-defender-service_31bf3856ad364e35_6.2.9200.16384_none_1e6fca32e090c9e9\MpAsDesc.dll --a---- 540 bytes [02:35 26/07/2012] [21:55 26/12/2013] EB4A8D0A24908557B5E4D33ADE443DC5
C:\Windows\WinSxS\amd64_windows-defender-service_31bf3856ad364e35_6.2.9200.16656_none_1e92403ce076a039\MpAsDesc.dll --a---- 150688 bytes [18:48 08/11/2013] [18:48 08/11/2013] A1C2796F698474BAA1ABD5B80B3835C8
C:\Windows\WinSxS\amd64_windows-defender-service_31bf3856ad364e35_6.2.9200.20763_none_1f0e0c3df99f0fef\MpAsDesc.dll --a---- 90 bytes [18:48 08/11/2013] [21:56 26/12/2013] 061DEB8CB427E5AC4C1E17F87E6030EC
C:\Windows\WinSxS\wow64_windows-defender-service_31bf3856ad364e35_6.2.9200.16384_none_28c4748514f18be4\MpAsDesc.dll --a---- 540 bytes [02:45 26/07/2012] [19:39 27/12/2013] 3F85692F917C0BA6A0E915528BA6E1BA
C:\Windows\WinSxS\wow64_windows-defender-service_31bf3856ad364e35_6.2.9200.16656_none_28e6ea8f14d76234\MpAsDesc.dll --a---- 150688 bytes [18:48 08/11/2013] [18:48 08/11/2013] DCD1DD102072EFFD763BE1C43EA7E6B4
C:\Windows\WinSxS\wow64_windows-defender-service_31bf3856ad364e35_6.2.9200.20763_none_2962b6902dffd1ea\MpAsDesc.dll --a---- 90 bytes [18:48 08/11/2013] [19:40 27/12/2013] 00884113B7DEE3AFDA57288CC987846B
Searching for "certutil.exe"
C:\Windows\SoftwareDistribution\Download\61b6a6052db9481008bdce9699875a42\x86_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.16595_none_b22647f804ca8723\certutil.exe --a---- 1013248 bytes [02:30 22/02/2014] [23:13 23/04/2013] 6498FE5EEE819307EDE2FE17CE849994
C:\Windows\System32\certutil.exe --a---- 1255936 bytes [18:50 08/11/2013] [18:50 08/11/2013] 3C300826241468F59D7C0244B4D8B867
C:\Windows\SysWOW64\certutil.exe --a---- 1013248 bytes [18:50 08/11/2013] [23:13 23/04/2013] 6498FE5EEE819307EDE2FE17CE849994
C:\Windows\WinSxS\amd64_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.16384_none_0e4eaf51bd20c8c3\certutil.exe --a---- 130290 bytes [00:08 26/07/2012] [19:47 26/12/2013] F624794C0EBE06332891F3CEFB03BF9F
C:\Windows\WinSxS\amd64_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.16595_none_0e44e37bbd27f859\certutil.exe --a---- 1255936 bytes [18:50 08/11/2013] [18:50 08/11/2013] 3C300826241468F59D7C0244B4D8B867
C:\Windows\WinSxS\amd64_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.20699_none_0ed2816ed641fd7f\certutil.exe --a---- 100667 bytes [18:50 08/11/2013] [19:48 26/12/2013] 3990DBA4AD3D6C53195347E85B46DDA6
C:\Windows\WinSxS\x86_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.16384_none_b23013ce04c3578d\certutil.exe --a---- 118239 bytes [00:11 26/07/2012] [19:42 27/12/2013] EF9CF0A33D1CA182DB4BE9C67DDBC297
C:\Windows\WinSxS\x86_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.16595_none_b22647f804ca8723\certutil.exe --a---- 1013248 bytes [18:50 08/11/2013] [23:13 23/04/2013] 6498FE5EEE819307EDE2FE17CE849994
C:\Windows\WinSxS\x86_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.20699_none_b2b3e5eb1de48c49\certutil.exe --a---- 64766 bytes [18:50 08/11/2013] [19:42 27/12/2013] 2EF5783326266E5059A47245BF0E58CB
Searching for "fastprox.dll"
C:\Windows\SoftwareDistribution\Download\bbcd2cf9b320a453d034b77497ec5af5\x86_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16683_none_bb3528a7dce75509\fastprox.dll --a---- 629248 bytes [02:30 22/02/2014] [04:22 10/11/2012] 5F2AB03D492FBF39203520EA5B0F397E
C:\Windows\System32\wbem\fastprox.dll --a---- 1004544 bytes [23:57 25/07/2012] [03:05 26/07/2012] 19304E66115DD1400182211B4FD7E73A
C:\Windows\SysWOW64\wbem\fastprox.dll --a---- 784896 bytes [23:58 25/07/2012] [03:18 26/07/2012] 992BD101F370B0D93A1131227BA342F6
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16384_none_1754bec39543e821\fastprox.dll --a---- 1024 bytes [05:28 26/07/2012] [21:22 26/12/2013] C4EE25EB4D48490A640A2A027175DB74
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16613_none_179f739f950c02a8\fastprox.dll --a---- 952 bytes [18:59 08/11/2013] [21:22 26/12/2013] CBE6755F1AC230928A4B7A40B0562EF7
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16683_none_1753c42b9544c63f\fastprox.dll --a---- 816640 bytes [18:59 08/11/2013] [18:59 08/11/2013] FC3DF763798BA2B3B8A74E0BB0D6E088
C:\Windows\WinSxS\amd64_microsoft-windows-wmi-core-fastprox-dll_31bf3856ad364e35_6.2.9200.16384_none_5412fabf0380d9df\fastprox.dll --a---- 1004544 bytes [23:57 25/07/2012] [03:05 26/07/2012] 19304E66115DD1400182211B4FD7E73A
C:\Windows\WinSxS\wow64_microsoft-windows-wmi-core-fastprox-dll_31bf3856ad364e35_6.2.9200.16384_none_5e67a51137e19bda\fastprox.dll --a---- 784896 bytes [23:58 25/07/2012] [03:18 26/07/2012] 992BD101F370B0D93A1131227BA342F6
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16384_none_bb36233fdce676eb\fastprox.dll --a---- 1082 bytes [05:28 26/07/2012] [19:52 27/12/2013] 0ADED59A8942C4022B630063F0BFE10E
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16613_none_bb80d81bdcae9172\fastprox.dll --a---- 1011 bytes [18:59 08/11/2013] [19:52 27/12/2013] C3687F98784C1AF182136BDBADC5961A
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16683_none_bb3528a7dce75509\fastprox.dll --a---- 629248 bytes [18:59 08/11/2013] [04:22 10/11/2012] 5F2AB03D492FBF39203520EA5B0F397E
Searching for "smipi.dll"
C:\Windows\SoftwareDistribution\Download\bbcd2cf9b320a453d034b77497ec5af5\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_0609729198b21d43\smipi.dll --a---- 102400 bytes [02:30 22/02/2014] [04:22 10/11/2012] 635E77F4B45CF16FC72F37F1BD6EDC9A
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16384_none_622908ad510eb05b\smipi.dll --a---- 524 bytes [05:28 26/07/2012] [21:22 26/12/2013] 08310E6CBB7045CD40909F3470B407C6
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16613_none_6273bd8950d6cae2\smipi.dll --a---- 110592 bytes [18:59 08/11/2013] [18:59 08/11/2013] CB888288B2C27CCE8668164D8A9DADE3
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_62280e15510f8e79\smipi.dll --a---- 110592 bytes [18:59 08/11/2013] [18:59 08/11/2013] CB888288B2C27CCE8668164D8A9DADE3
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16384_none_060a6d2998b13f25\smipi.dll --a---- 496 bytes [05:28 26/07/2012] [19:52 27/12/2013] B1E26D26F0BC945B3B63C6E3B0331CC3
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16613_none_06552205987959ac\smipi.dll --a---- 423 bytes [18:59 08/11/2013] [19:52 27/12/2013] FA83DF83DB24704374E6609B82DB4B98
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_0609729198b21d43\smipi.dll --a---- 102400 bytes [18:59 08/11/2013] [04:22 10/11/2012] 635E77F4B45CF16FC72F37F1BD6EDC9A
-= EOF =-
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
Out of all the files listed I can only match up a single entry. The following commands should fix this item.
1) takeown /F "C:\ESD\Windows\sources\luainstall.dll" /R /A
2) icacls "C:\ESD\Windows\sources\luainstall.dll" /GRANT ADMINISTRATORS:F
3) copy /y "C:\ESD\Windows\sources\luainstall.dll" "C:\Windows\System32\luainstall.dll"
If someone running the same version of Windows 8 as Rich could post the SystemLook.txt that would be helpful.
Had to drop /R from takeown as it generated a "Not a directory" error.
C:\Users\rrkurtz>takeown /F "C:\ESD\Windows\sources\luainstall.dll" /A
SUCCESS: The file (or folder): "C:\ESD\Windows\sources\luainstall.dll" now owned by the administrators group.
C:\Users\rrkurtz> icacls "C:\ESD\Windows\sources\luainstall.dll" /GRANT ADMINISTRATORS:F
processed file: C:\ESD\Windows\sources\luainstall.dll
Successfully processed 1 files; Failed processing 0 files
C:\Users\rrkurtz>copy /y "C:\ESD\Windows\sources\luainstall.dll" "C:\Windows\System32\luainstall.dll"
Access is denied.
0 file(s) copied.
Tried to take ownership of "C:\Windows\System32\luainstall.dll" but that failed.
C:\Users\rrkurtz>icacls "C:\Windows\System32\luainstall.dll" /GRANT ADMINISTRATORS:F
C:\Windows\System32\luainstall.dll: Access is denied.
Successfully processed 0 files; Failed processing 1 files
Aha! Installed the Takeown registry hack then used the context menu Take Ownership on luainstall.dll. Now the copy worked.
1 file(s) copied.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
Reran SystemLook:
SystemLook 04.09.10 by jpshortstuff
Log created at 14:12 on 24/02/2014 by rrkurtz
WARNING: SystemLook running under WOW64. Use SystemLook_x64 for accurate results.
C:\Windows\System32\luainstall.dll --a---- 39424 bytes [02:01 26/07/2012] [03:18 26/07/2012] 902B161E360563DED4F3099C55062411
C:\Windows\WinSxS\amd64_microsoft-windows-luainstaller_31bf3856ad364e35_6.2.9200.16384_none_718018daf20f86f3\luainstall.dll --a---- 50176 bytes [01:55 26/07/2012] [03:06 26/07/2012] FFFF498E680E92052683AAFDFAE4D981
C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_62280e15510f8e79\luainstall.dll --a---- 50176 bytes [18:59 08/11/2013] [18:59 08/11/2013] 8AD518DEB9A867808806CFE0CB953FC9
C:\Windows\WinSxS\amd64_microsoft-windows-wmi-ntevent-provider_31bf3856ad364e35_6.2.9200.16384_none_492347b5369e9a83\ntevt.dll --a---- 239104 bytes [23:56 25/07/2012] [03:06 26/07/2012] 1DCDBC457B31CF69C6C52125AB4D343A
C:\Windows\System32\certutil.exe --a---- 1013248 bytes [18:50 08/11/2013] [18:50 08/11/2013] AA6F0DDF483739E723EDFDCCFF83D81B
C:\Windows\SysWOW64\certutil.exe --a---- 1013248 bytes [18:50 08/11/2013] [18:50 08/11/2013] AA6F0DDF483739E723EDFDCCFF83D81B
C:\Windows\WinSxS\x86_microsoft-windows-certutil_31bf3856ad364e35_6.2.9200.16595_none_b22647f804ca8723\certutil.exe --a---- 1013248 bytes [18:50 08/11/2013] [18:50 08/11/2013] AA6F0DDF483739E723EDFDCCFF83D81B
C:\Windows\System32\wbem\fastprox.dll --a---- 784896 bytes [23:58 25/07/2012] [03:18 26/07/2012] 992BD101F370B0D93A1131227BA342F6
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack-admin_31bf3856ad364e35_6.2.9200.16683_none_bb3528a7dce75509\fastprox.dll --a---- 629248 bytes [18:59 08/11/2013] [18:59 08/11/2013] FF1B827D398A7F86B2430CD59C1B3BE3
C:\Windows\WinSxS\x86_microsoft-windows-servicingstack_31bf3856ad364e35_6.2.9200.16683_none_0609729198b21d43\smipi.dll --a---- 102400 bytes [18:59 08/11/2013] [18:59 08/11/2013] 3C895823F27B8FAE6F5AA3A56A0926C4
-= EOF =-
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
For some reason that did the exact opposite of what was supposed to happen.
Try this:
Copy the file here.. C:\Windows\WinSxS\amd64_microsoft-windows-luainstaller_31bf3856ad364e35_6.2.9200.16384_none_718018daf20f86f3\luainstall.dll
Paste it into.. C:\Windows\System32\
Next, make sure you have all Windows Updates installed, including optional ones.
Open Windows Defender and run a manual Update.
Rerun SFC /scannow.
