Cannot lower Critical Battery Level in Power Options
  1. #21
    Quote Originally Posted by adamf View Post
    How about you try ACPI? Windows Dev Centre Hardware
    Quote Originally Posted by Microsoft
    Design capacity of Low Indicates the critical battery level at which Windows must immediately shut down or hibernate before the system powers off. Must be set to a value between 0 and 5 percent of the battery design capacity
    This is really interesting reading. Particularly the bit where it says it must be set to a value between 0 and 5 to be ACPI compliant. Really keen to hear what HP has to say when (and if) they call back.
    I checked the battery driver that is installed on my laptop. It's ironic that it's listed as ACPI compliant.
    I wonder if there is a different ACPI driver that I can install that would bypass HP's one?
  2. #22
    Well, it's Tuesday and no surprise I did not get the promised callback from HP support. So I took the initiative to call them to follow up. Was told that they will now escalate the matter to the highest priority and I will get a callback in 1 hour. I've waited more than an hour and no word from HP again. Will have to chase them again tomorrow.
    In the meantime, I'm gonna try disabling the "Microsoft ACPI-Compliant Control Method Battery" and see if it works. I can verify that when I disable it that it at least lets me change the Critical Battery level in Power Options to any percentage I want. I just need to run the laptop now to see if it is merely cosmetic or if it will actually go lower than 7%. Will report back in a few hours.
  3. #23
    Here is an update on things:
    Disabling the "Microsoft ACPI-Compliant Control Method Battery" does indeed allow me to run the laptop below 7%, however, this method is not a practical workaround because doing so also prevents other useful power management features.
    I have an email response from HP and they advise that the MSDN link is only relevant for systems supporting Connected Standby and that the HP Spectre x360 does not support Connected Standby. They further added that ACPI specification 3.9.4 Low Battery Levels do not specify any value as a maximum.
    While I agree with what HP has said is true, I do not follow their logic in setting it at 7%. I understand that a computer supporting Connected Standby would experience a far greater battery drain than one that supports only the traditional Sleep/Hibernate power states. If anything, I expect it to be set at something lower than the 5% maximum of a Connected Standby laptop.
    I've even gone out to the shops to sample a range of different laptops - ones from Dell, Acer, Asus, Toshiba and Lenovo. All of these other manufacturers have set the critical battery level to at most 5%. Some are 3% and others even allow you to go all the way to 0%. Only HP laptops fix theirs at 7%. I can only infer that only HP has decided that their batteries are somehow inferior to other manufacturers'.
    I've sent another email to HP to see if they will issue some sort of fix, so I'll just have to wait to hear from them again.
    (After this, I don't think I will buy another HP product ever again)
  4. #24
    United States
    Windows 8.1 Pro 64-bit
    Just for info my Acer allows 5% for lowest setting.
Page 3 of 3 FirstFirst 123
Options Missing from Power Options Advanced Settings
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
Power Options - Add or Remove Link State Power Management
Kernel-Processor-Power Event ID 37 (Warning Level entry)
Recently I noticed a game that I had been playing had started to stutter and slowdown more than usual, the performance issues were to be expected as the games engine is notorious for being poorly optimized, however these occurrences were fairly rare in comparison to the issues i'm experiencing now....
Performance & Maintenance
Giving specific applications administrator level power
Hi, I have a normal standard account on my Win8 and have the admin level password. On the normal account, steam can start and run games easily. However, Origin (by EA) does not. Every time I try to log into origin, it wants the administrator level password, which is annoying. I tried...
User Accounts and Family Safety
A Lower Level "Start" Screen
Hi All, I am new to Windows 8, which I am using with a non-touch screen so I am dependent on the mouse for controlling actions. The Start Screen has enough items on it to require me to scroll across to see them all, even when grouped. I would like to be able to have a second (lower level)...
Hard drive just keeps running lower and lower on space
About 1-2 weeks ago, I had 15GB of space left on my SSD that is solely committed to OS and drivers. Today, I have 2.9GB left. I have downloaded nothing, and I have changed nothing. What is going on? Any programs to help me take a closer look at why my SSD space is disappearing? I've had this OS for...
No low battery level warning message since windows 8
Hi, I hope someone can help. I have an Dell Inspiron 1545 laptop that was originally Vista but now is running 8 pro. The problem I have is that since I upgraded to Windows 8 Pro, I no longer receive an on-screen message warning of low battery level. I however still have the battery level...
