Navigation Pane Show all folders - Turn On or Off
How to Turn Navigation Pane "Show all folders" On or Off in Windows 8 and 8.1
This tutorial will show you how to turn Show all folders on or off in the navigation pane of Windows Explorer in your user account in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
If you turn on Show All Folders, it will also add your user profile folder, Control Panel, and Recycle Bin items in the navigation pane of Windows Explorer.
If you have "Show all folders" checked, then the Show in Navigation Pane option for libraries will be grayed out.
EXAMPLE: "Show all folders" Turned On and Off
To Turn "Show all folders" On or Off from within Navigation Pane
1. Open File Explorer, and do step 2 or 3 below for what you would like to do​
2. Right click or press and hold on an empty area in the navigation pane, and go to step 4 below. (see screenshot below)​
3. Click/tap on the View tab, click/tap on the Navigation Pane button in the ribbon, and go to step 4 below. (see screenshot below)​
5. To Turn On "Show all folders" in Navigation Pane
A) Click/tap on Show all folders to check it. (See screenshot above)​
6. To Turn Off "Show all folders" in Navigation Pane
A) Click/tap on Show all folders to uncheck it. (See screenshot above)​
To Turn "Show all folders" On or Off from within Folder Options
1. Open Folder Options, click/tap on the General tab, and do step 2 or 3 below for what you would like to do. (see screenshot below)​
2. To Turn On "Show all folders" in Navigation Pane
A) Check the Show all folders box, and click/tap on OK. (see screenshot above)​
3. To Turn Off "Show all folders" in Navigation Pane
A) Uncheck the Show all folders box, and click/tap on OK. (see screenshot above)​
To Turn "Show all folders" On or Off using a BAT File Download
NavPaneShowAllFolders DWORD
0 = off
1 = on
A) Click on the Download button below to download the file below, and go to step 4 below.​
Turn_On_Show-all-folders_in_Navigation_Pane.bat
Turn_Off_Show-all-folders_in_Navigation_Pane.bat
4. Save the .bat file to the desktop.​
5. Double click/tap on the downloaded .bat file to run it.​
6. If prompted, click/tap on Run and Yes (UAC).​
NOTE: If you like, you can stop getting the Run prompt by unblocking the downloaded .bat file.​
7. You will now notice a command prompt open and your screen flash as explorer is restarted to apply the registry changes.​
  • Turn_On_Show-all-folders_in_Navigation_Pane.bat
  • Turn_Off_Show-all-folders_in_Navigation_Pane.bat
I have W8.1 64bit pro installed. In the Navigation pane I have "show all folders" unchecked. However all the folders under SkyDrive are shown.
I have tried selecting Show all folders and then unchecked it, in the hope that this would collapse the folders under SkyDrive, but it did not.
Can you suggest what I may try next?
    W8.1
    N/A
    i5-3470
    ASRock B75M R2.0
    16GB
    Intel(R) HD Graphics
    IE 11
    Windows defender
Hello dsim, and welcome to Eight Forums.
The "Show all folders" setting doesn't apply to the separate "SkyDrive" group in the navigation pane.
You should be able to click on the arrow to the left of the SkyDrive folder or double click on the SkyDrive folder in the navigation pane to collapse it.
Hope this helps, :)
Thanks Shawn. I had previously collapsed the SkyDrive folder list by clicking on its arrow, but when next opening File Explorer all these folders were again displayed.
However since reading your advice I right clicked SkyDrive and selected Collapse from there. Now File Explorer opens with SkyDrive collapsed.
    W8.1
    N/A
    i5-3470
    ASRock B75M R2.0
    16GB
    IE 11
    Windows defender
Great news. By default, it should open the same way as it was last closed. :)
I am sorry to report that using the Collapse feature no longer works.
Is there some way to make sure that file explorer opens the same way that it last closed?
    W8.1
    N/A
    i5-3470
    ASRock B75M R2.0
    16GB
    IE 11
    Windows defender
Yes, that fixed it, thankyou Shawn
    W8.1
    N/A
    i5-3470
    ASRock B75M R2.0
    16GB
    IE 11
    Windows defender
You're most welcome. :)
