Tile on Start for Designer Media Windows Help Forums
How to Create Designer Media Windows Help Forums Tiles on Start Screen
Here is a way to make Designer Media’s Windows help forums page(s) live tiles to include and make use of the forums’ live feed. They will randomly scroll with the latest post titles. These are constructed via the Modern IE version only. A “non-live” regular tile can be constructed using desktop IE.
Live tiles are automatically created bookmarking any forum site page. In the above example the left and middle live tiles shown are bookmarks of my Eight and Ten Forums Subscriptions pages respectively and the right is 8/10 AllCut, which all open automatically to their respective page.
AllCut is presented by JDobbsy1987 here: Live Posts/View Overview
Links:
Windows VistaForums
Windows SevenForums
Windows EightForums
Windows TenForums
PC Help Forums
CONTENTS:
  • Option One: Make Modern IE forum page live tile
  • Option Two: Make Desktop IE "nonlive" regular tile
Option One
1. Open Modern IE and navigate to the forum page you desire to use. Right click or hold on a blank area the page. A Tab/Address popup menu will appear. Left click or press the Favorites’ star button.​
2. Favorites menu will appear. Right click or press the "Pin to Start" pin button.​
3. A popup editing box will appear. Type in a name. It can be whatever you desire. Left click or press “Pin to Start”.​
The live tile will be placed at the end of your Start Screen. Place it wherever you desire. Use Brink’s tutorial to learn how: Start Screen Apps - Organize into Groups
You may resize the tile to show more data. Wide size and live is default. You may unpin, resize, and/or turn the live tile off or on at any time by right clicking or finger-hold the tile or keyboard navigate to it to focus on it and tap the menu key to obtain a context menu.
A live tile can be made for any site that uses live feeds
Option Two
1. Open Desktop IE and navigate to the forum page you desire to use. Left click or press the Tools Gear icon button at the upper right of the page.​
2. A context menu will appear. Left click or press “Add site to Apps”.​
3. Go to your Apps Screen and look for the Link. It will be under the letter that the forum's name starts with. For example “V” for "VistaForums”, "T" for "TenForums", etc. The difference is what it opens to. There can only be one listed in the Apps page per browser version at a time. Any new one created will take place of the old one. Take note of the difference if you have two. The top one is the Modern and the bottom one is Desktop.​
4. Right click or hold on the Desktop IE version link and choose “Pin to Start”. It will be placed last on your Start Screen to be moved where desired.​
5. The results look like this.​
The tile will be placed at the end of your Start Screen. Place it wherever you desire. Use Brink’s tutorial to learn how: Start Screen Apps - Organize into Groups
You may unpin, pin to Taskbar, open file location, and/or resize the tile at any time by right clicking or finger-hold the tile or keyboard navigate to it to focus on it and tap the menu key to obtain a context menu. There are only two sizes. Medium size is default.
A tile can be made for any site.
That’s it. Enjoy!
Very helpful tutorial there, Tony! Thanks! :)
-Chuck
    Windows 10 Pro 64-bit
    Self-built/ Custom
    AMD FX-6300
    MSI 970A-G43
    Crucial Ballistix Sport 8GB
    Asus GTX 750 ti
    HP w2207h
    1680x1050
    Seagate 1TB 3.5" 7200 Hybrid Internal Hard Drive
    Crucial M500 240GB 2.5-inch Internal SSD
    EVGA 500 Watt 80+ Certified ATX Power Supply
    Fractal Design Define R4
    Corsair Hydro Series H55 Quiet Edition Liquid CPU Cooler
    CM Storm Devastator - Red
    Logitech Wireless Performance Mouse MX
    Really fast.
    AVG
    Logitech G230 Headset
Great job Tony. :)
Thanks, Guys. :)
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
