Wireless Network Connect Automatically - Start or Stop
    How to Start or Stop Connect Automatically to Wireless Network in Windows 8
    Published by Brink is offline
    30 Aug 2014
    Default Wireless Network Connect Automatically - Start or Stop
    Published by
    Brink's Avatar
    If you have a laptop or a PC with a wireless network adapter, you can see a list of available wireless networks in your area, and then connect to one of those networks. The wireless networks will only appear if your PC has a wireless network adapter installed, the adapter is turned on, and the wireless access point is in range.
    A wireless (Wi-Fi) network profile contains the SSID (network name), password key, and security information to be able to connect to a wireless network.
    You can either connect to a wireless network manually for just that session, or have Windows always automatically connect to the wireless network when it's within range.
    This tutorial will show you how to start or stop automatically connecting to a wireless network profile in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1.
    Wireless Network Connect Automatically - Start or Stop Preparation Wireless Network Connect Automatically - Start or Stop
    To See Connection Mode of Wireless Network Profile
    This will let you see if the connection mode of a wireless network profile on your PC is set to connect automatically or connect manually to.
    Afterwards, you could do OPTION ONE or OPTION TWO below to turn on or off connect automatically to a wireless network.
    1. Open a command prompt.
    2. In the command prompt, copy and paste the command below, and press Enter. (see screenshot below)
    NOTE: This will show all wireless profiles on each interface on your PC.
    netsh wlan show profiles
    2. In the command prompt, type the command below, and press Enter. (see screenshot below)
    netsh wlan show profile "ProfileName"
    Substitute ProfileName in the command above with the actual name of your wireless network (WLAN) profile.
    For example: netsh wlan show profile "Brink-Router2"
    3. You will now see if the WLAN profile is set to connect automatically or connect manually.
    Wireless Network Connect Automatically - Start or Stop OPTION ONE Wireless Network Connect Automatically - Start or Stop
    Start or Stop Connect Automatically to Wireless Network in Networks
    1. Do step 2 or 3 below for how you would like to do.
    2. To Stop Automatically Connecting to Connected Wireless Network Profile
    A) While in Networks, click/tap on the listed wireless network (ex: Brink-Router2) that you are currently connected to, and click/tap on Disconnect. (see screenshot below)
    See OPTION FOUR in the tutorial link below for more details on how to do this.
    How to Connect To or Disconnect from a Wireless Network in Windows 8 and 8.1
    3. To Start Automatically Connecting to Wireless Network Profile
    A) If you are currently connected to the wireless network, then you will need to do step 2 above to disconnect from it first.
    B) While in Networks, click/tap on the listed wireless network (ex: Brink-Router2) that you want to connect to, check the Connect automatically box, and click/tap on Connect. (see screenshot below)
    Wireless Network Connect Automatically - Start or Stop OPTION TWO Wireless Network Connect Automatically - Start or Stop
    Start or Stop Connect Automatically to Wireless Network in Command
    You can use this option on any of your wireless network profiles. It doesn't matter if you are currently connected to them or not.
    2. Do step 3 or 4 below for how you would like to do.
    3. To Stop Automatically Connecting to a Wireless Network Profile
    If you are currently connected to the WLAN profile you specified in the command, then this will disconnect you from it now.
    A) In the command prompt, type the command below, and press Enter. (see screenshot below)
    netsh wlan set profileparameter name="ProfileName" connectionmode=manual
    For example:
    netsh wlan set profileparameter name="Brink-Router2" connectionmode=manual
    4. To Start Automatically Connecting to a Wireless Network Profile
    This will disconnect you from any currently connected WLAN profile, and will automatically connect you to the WLAN profile you specified in the command when it's within range.
    netsh wlan set profileparameter name="ProfileName" connectionmode=auto
    For example:
    netsh wlan set profileparameter name="Brink-Router2" connectionmode=auto
    5. When finished, you can close the command prompt if you like.
    @Brink im having an issue my Win 8 stopped automatically connecting my wifi,and when i try to put the command
    i get this error function wlansetprofilelist returns error 5, access denied
    Also im having alot of problems with privileges but im running as an admin!
    Any help!
  3. #2
    Hello coldlm,
    Use an elevated command prompt to see if the command will work with in it instead.
    Elevated Command Prompt - Open in Windows 8
  4. #3
    Quote Originally Posted by Brink View Post
    Hello coldlm,
    Already did and still same error
  5. #4
    As a test, enable the built-in Administrator, sign in to it, and run the command again to see if you are able then.
    Administrator account - Enable or Disable in Windows 10 - Windows 10 Forums
  6. #5
    Here is what happened
    Activated Admin account, and logged in.
    First thingi saw was that win 8 first metro apps was empty, and stayed there, it didnt jump to desktop until i hit crtl , alt, delete, and i chose task manager,
    then it took me to desktop with this error
    That error kept showing every time i try to right click and refresh or when i try to click on desktop to see my hard drive!
    Also when i tried to double click any folder it shows that i dont have permission to access it click continue to access it when i click continue nothing happens!
    One final error
    I couldn't start CMD because it kept showing an error that the location of explorer.exe is invalid!
    My computer is messed up
  7. #6
    Yeah, I think it's time to consider a clean install of Windows.
  8. #7
    I thought there could be a trick to fix it but yeah i guess i have to,
    also i know all my problems started when i took ownership of Windows folder!
  9. #8
    Yeah, taking ownership of Windows or the C: drive is never good.
  10. #9
    Alright thanks your help.
Page 1 of 2 12 LastLast
A couple of days ago, my network manager started misbehaving after a system update. The computer has trouble connecting to every network it can find and when it finally connects, the connection becomes limited after 10 minutes. It happens to all networks I try to connect to and other devices in my...
This is a random issue, sometimes I can connect just fine, and usually a restart of my laptop lets me connect. However sometimes when I try to enter the password it does not work. I get the error message 'the network security key is not correct. Please try again.' I know for a fact that my...
Upgraded ThinkPad laptop via ethernet from 8 to 8.1 then tested out fine. Shutdown for the night and removed the ethernet cable. Day later the Lenovo booted fine and the wireless SSID showed 5 bars on the charms bar. Clicked to connect and was prompted for the pw which was entered correctly. ...
Hi, Here is the story of my long struggle with this issue. I have a Lenovo T520 and installed Windows 8 little over two months ago. After the upgrade I started having trouble connecting to different wireless networks ( ATT Uverse at home, Verizon Jetpack 4620LE, Verizon Pantech UML 290 and wifi...
Pretty much says it all, upgrade from Win 7 was dropping connections but after I disabled allow the computer to turn off the wireless it doesn't drop the connection but I have to manually connect it every time I boot or logout/in. Netgear Rangemax Wireless-N Dual Band USB if that makes a difference.
I have an Acer IconiaTab W500 with Windows 8 developer preview installed on it and I cannot get it to connect to my Cisco 1142 APs. I have a Guest network that is for b/g speeds only and requires . I type the password in and Windows comes back and says something is wrong with the adapter or the...
I successfully setup Windows 8 Consumer Preview and correctly setup and connected to an existing and working hidden wireless network. This network is hidden for a reason and working with all other devices. How can I configure W8 to automatically connect to this network when in range? I was...
