Power Options - Add or Remove "System cooling policy"
How to Add or Remove "System cooling policy" in Power Options in Windows
The System cooling policy power option allows you to specify the cooling mode you want to use for your system.
  • Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort.
  • Passive = Slow the processor to cool, and only increasing fan speed to cool as a last resort.
This tutorial will show you how to add or remove the "System cooling policy" setting under Processor power management in Power Options for all users in Vista, Windows 7, and Windows 8.
EXAMPLE: "System cooling policy" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\94D3A615-A899-4AC5-AE2B-E4D8F634367F
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "System cooling policy" from Power Options
Remove_System_cooling_policy.reg
3. To Add "System cooling policy" to Power Options
Add_System_cooling_policy.reg
  • Add_System_cooling_policy.reg
  • Remove_System_cooling_policy.reg
Another great tut Shawn :thumbsup:
Nommy
    Microsoft Windows 8.1 64-bit Professional
    Dell Inspiron 5547
    Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz
    Dell Inc. 08KNCD
    8.00 GB (2 x 4.00 GB)
    AMD Radeon R7 M265
    1366 x 768 x 4294967296 colors
    (1) 1TB ST1000LM024 HN-M101MBB (2) 2TB Western Digital external hard drive (3) 500GB Packard Bell external hard drive
    Corsair Vengeance M60
    Firefox, Chromium
    Windows Defender, Malwarebytes
