Power Options - Add or Remove "Min/Max processor state"
  1. #10
    Hello Nabeel, and welcome to Eight Forums.
    Check to see if you may have Intel Power Management or some other 3rd party utility installed that may be overriding your Windows power plan settings.
  2. #11
    Sorry for sounding like a noob but wouldn't choosing a power plan like high performance in Power Options fix all this? Or is there something I don't know?
  3. #12
    Hello Chris, and welcome to Eight Forums.
    No worries. See my signature about asking questions.
    These two settings are to be able to set the min/max processor state to what you may want them to be other than the default defined by the active power plan.
Page 2 of 2 FirstFirst 12
How to Add or Remove "When sharing media" in Power Options in Windows The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme. The Slide show power option allows...
How to Add or Remove "System cooling policy" in Power Options in Windows The System cooling policy power option allows you to specify the cooling mode you want to use for your system. Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort. Passive...
How to Add or Remove "Turn off hard disk after" in Power Options in Windows The "Turn off hard disk after" power option setting lets users set to have hard disks power down after a specified time of inactivity is detected. When you set to turn off hard disks after idle, there will be a...
How to Add or Remove "Allow wake timers" in Power Options in Windows The "Allow wake timers" power option setting enables or disables Windows to automatically wake your computer from sleep on a timer for scheduled tasks and other programs. This tutorial will show you how to add or remove...
How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows Away Mode in Windows is similar to Sleep and Hibernate Mode, it turns off the power of most equipment to save energy and can be fast woken up. Away Mode is designed to enable media PC scenarios that include background...
