How to Create System Configuration (msconfig) Shortcuts in Windows
Information
System Configuration (msconfig) is a tool that can help identify problems that might prevent Windows from starting correctly.
This tutorial will show you how to download or create System Configuration (msconfig) shortcuts that open directly to the General, Boot, Services, Startup, or Tools tab in Vista, Windows 7, and Windows 8.
Note
For more information about msconfig, see: Using System Configuration (msconfig) - Windows Help
Tab | Description |
General | Lists choices for startup configuration modes:
Boot | Shows configuration options for the operating system and advanced debugging settings, including:
Services | Lists all of the services that start when the PC starts, along with their current status (Running or Stopped). Use the Services tab to enable or disable individual services at startup to troubleshoot which services might be contributing to startup problems. |
Startup | In Windows 8 and 8.1, you can now manage startup items in Task Manager. |
Tools | Provides a convenient list of diagnostic tools and other advanced tools that you can run. |
EXAMPLE: System Configuration (msconfig)
To Download a "System Configuration" (msconfig) Shortcut
1. Do step 2 to 6 below for what tab you want the msconfig shortcut to open to.
2. System Configuration Shortcut that Opens to the General Tab
A) Click/tap on the download button below to download the file below.
msconfig_General tab_Shortcut.zip
3. System Configuration Shortcut that Opens to the Boot Tab
msconfig_Boot_tab_Shortcut.zip
4. System Configuration Shortcut that Opens to the Services Tab
msconfig_Services_tab_Shortcut.zip
5. System Configuration Shortcut that Opens to the Startup Tab
msconfig_Startup tab_Shortcut.zip
6. System Configuration Shortcut that Opens to the Tools Tab
msconfig_Tools_tab_Shortcut.zip
7. Save the .zip file to your desktop.
8. Open the downloaded .zip file, and extract (drag and drop) the shortcut to your desktop.
9. Unblock the shortcut.
10. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
11. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
12. When finished, you can delete the downloaded .zip file if you like.
To Create a "System Configuration" (msconfig) Shortcut
1. Right click or press and hold on an empty area on your desktop, and click/tap on New and Shortcut.
2. Copy and paste the location below you want into the location area for the tab you want the System Configuration shortcut to open to, and click/tap on the Next button. (see screenshot below)
Location | Tab |
msconfig -1 | General |
msconfig -2 | Boot |
msconfig -3 | Services |
msconfig -4 | Startup |
msconfig -5 | Tools |
3. Type in a name (ex: "msconfig Boot tab") you want for the shortcut, and click/tap on the Finish button. (see screenshot below)
4. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
5. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
