Mouse and Touchpad PC settings Shortcut - Create
How to Create a "Mouse and Touchpad" PC Settings Shortcut in Windows 8.1
This tutorial will show you how to create or download a Mouse and Touchpad settings shortcut that opens directly to the Mouse and Touchpad settings in PC settings in Windows 8.1 and Windows RT 8.1.
Tip   Tip
Here's a custom icon if you would like to change the shortcut's icon with it.
EXAMPLE: "Mouse and touchpad" in PC settings in Windows 8.1
To Download a "Mouse and Touchpad" PC settings Shortcut
Mouse_and_touchpad_Shortcut.zip
3. Open the .zip file and extract (drag and drop) the shortcut to your desktop.​
4. Unblock the extracted shortcut.​
6. When finished, you can delete the downloaded .zip file if you like.​
To Manually Create a "Mouse and Touchpad" PC settings Shortcut
1. Right click or press and hold on an empty area of your desktop, and click/tap on New and Shortcut.​
If you do not have a US English Windows 8.1 installed, then you will need to change the en-US folder name in the command below for the folder name with your language instead for this to work.
%windir%\explorer.exe %localappdata%\Packages\windows.immersivecontrolpanel_cw5n1h2txyewy\LocalState\Indexed\Settings\[COLOR=#ff0000][B]en-US[/B][/COLOR]\AAA_SystemSettings_Input_Touch_EnableTouchPad.settingcontent-ms
3. Type Mouse and Touchpad for the name, and click/tap on the Finish button. (see screenshot below)​
4. Right click or swipe down on the new Mouse and Touchpad shortcut, and click/tap on Properties.​
6. In the line under "Look for icons in this file", copy and paste the location below, and press Enter. (see screenshot below)​
%SystemRoot%\system32\DDORes.dll
  • Mouse-Touchpad.ico
  • Mouse_and_touchpad_Shortcut.zip
