Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8
Information
This tutorial will show you how to add or remove Advanced System Properties to the "My Computer" (Vista/Windows 7) or "This PC" (Windows 8) context menu for all users in Windows.
Note
In Vista and Windows 7, this is for when users right click on Computer from the Start Menu, navigation pane in Windows Explorer, or desktop icon.
In Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1, this is for when users right click or swipe down on This PC from the navigation pane in File Explorer, or the Computer desktop icon.
EXAMPLE: Advanced System Properties
EXAMPLE: Advanced System Properties in "My Computer" and "This PC"context menu
1. To Add "Advanced System Properties" to "This PC" Context Menu
A) Click/tap on the Download button below to download the file below, and go to step 3 below.
Add_Advanced_System_Properties_to_This-PC_Context_Menu.reg
2. To Remove "Advanced System Properties" from "This PC" Context Menu
Remove_Advanced_System_Properties_from_This-PC_Context_Menu.reg
3. Save the .reg file to your desktop.
4. Double click/tap on the downloaded .reg file to merge it.
5. If prompted, click on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve the merge.
6. You can now delete the downloaded .reg file if you like.
That's it
