Power Options - Add or Remove "Dim display after"
Add or Remove "Dim display after" in Power Options in Windows
The display can use more power than any other part of a PC. Reducing the display brightness level can help extend your battery life before needing to recharge.
The Dim display after setting under Display in Power Options specifies how long your computer is inactive before your display(s) dims.
This tutorial will show you how to add or remove the Dim display after setting under Display in Power Options for all users in Vista, Windows 7 and Windows 8.
If you did not originally have the Dim display after option available, then it means that it is not supported on your PC.
Instead, your display(s) will automatically dim by the percentage set in "Dimmed display brightness" exactly 15 seconds before what is set in "Turn off display after".
EXAMPLE: "Dim display after" added to Advanced Power Settings
2. Add "Dim display after" to Advanced Power Settings
Add_Dim_Display_After.reg
3. Remove "Dim display after" from Advanced Power Settings
Remove_Dim_Display_After.reg
7. You can now delete the downloaded .reg file if you like.
  • Remove_Dim_Display_After.reg
  • Add_Dim_Display_After.reg
Oh maaaaaaaaaan ... you are AWESOME, Brink! Thank you so much for the easy tweak!
I wish you the best of holidays! :)
    Toshiba Qosmio X505-Q894
    Intel Core i7 740QM(1.73GHz)
    8 GB
    NVIDIA GeForce GTX 460M
    18.4" (main) + 2 external monitors
    1680x945 (main)
    Overall, very happy with this laptop -- great for work & was very good for gaming when I originally bought it (haven't tried any games last year or so).
You're most welcome TBolt. I hope you have a great holidays as well. :)
{edit}
No luck thus far. Updated NVIDIA drivers again -- the laptop screen still won't dim.
Well, this must be a Microsoft or NVIDIA thing that they need to fix. :) Even though I set the dim to 1 minute in both Balanced Mode & High Performance Mode, the laptop display is not dimming.
  • I disconnected external monitors/TVs.
  • I even turned off the mouse to make sure there was no input to the PC.
  • No videos playing.
It was a brilliant effort though, Brink! :)
    8 GB
    1680x945 (main)
Well, so much for that. What I have set for "Dim display after" doesn't get applied for me as well.
However, I noticed that the display will automatically dim by the percentage set in "Dimmed display brightness" exactly 15 seconds before what is set in "Turn off display after". :party:
However, I noticed that the display will automatically dim by the percentage set in "Dimmed display brightness" exactly 1 minute before what is set in "Turn off display after". :party:
Interesting. For me, the main laptop display dimmed 15 seconds before the screen turned off at 2 minutes. Tested it twice - same result.
So, do you feel this is just a bug that MS will need to fix?
Thank you, Brink!
    8 GB
    1680x945 (main)
I don't think it's a bug, but was changed for whatever reason. Oops, yep 15 seconds.
Hi Brink,
I just tried your reg fix and yes, it brings the option back up in the advanced settings but it doesn't have any effect.
My laptop is a HP Compaq 6710b core 2 duo T7500 2.2GHz 3GB RAM now running Win 8.1 update.
It was working fine in Win 8 but not in the Win 8.1 update.
I have used the Intel driver update program you suggested in another post and all my drivers are up to date and no problems in the device manager.
    8.1 update
Hello Frog, and welcome to Eight Forums.
It appears that the Dim display after option is no longer supported on your PC.
Instead, your display(s) will automatically dim by the percentage set in "Dimmed display brightness" exactly 15 seconds before what is set in "Turn off display after". :(
Awesome, thank you Brink. That was one of the many useful features they removed between Win7 and Win8.1. Personally I don't see why they need to make a desktop computer behave like a mobile device. Give it up, Microsoft, a 25-lb tower will never be a tablet no matter how much fat you trim on the software side.
Why don't they have the "dim display after x min" feature in W8.1?
According to IBM:
"Dim the display does not display in the edit plan settings. This new behavior is designed for Windows® 8.1. Dimming will be set to occur 15 seconds before display off."
So is this true? For W8.1, it will automatically dim the screen 15sec before shutting off, but there's no option to set it to dim after a certain idle time?
    Windows 8.1 Pro 64
    Tablet
    Microsoft Surface Pro 3
    i5-4300U
    4 GB
    Intel HD 4000
    3 x 2
    2160 x 1440
    128 GB SSD
    Rip-off type cover
    Avast, Malwarebytes, Online Armor
Hello Crimson,
Only for what is in the blue note box at the top of the tutorial in Windows 8.1. :(
I don't understand. It just says it won't work if it's not supported by the PC. So it's something built in the hardware? Because the desktop I built is just a normal desktop build. So it's only for something like laptops where the display is integrated into the hardware of the system?
    Windows 8.1 Pro 64
    Tablet
    i5-4300U
    4 GB
    Intel HD 4000
    3 x 2
    2160 x 1440
    128 GB SSD
    Rip-off type cover
Correct. Desktops would not have this as an option. Only PCs that have a battery would, but I have not seen this setting available since Windows 8.1. :(
Can you give a link for a "Add_Dim_Display_After.reg" file download for windows 8.1??
Oh! I have a Lenovo laptop (brand new one too)
    windows 8.1
    lenovo ideapad 710
    intel 4700
    intel
    nvidia 745
    jbl
    TFT
    FULL
    1TR HRBRID
    ie
    norton 360 v21
Hello usawake, and welcome to Eight Forums.
This tutorial is for Windows 8.1 as well. Windows 8 is just generic for all Windows 8 builds and versions. :)
Be sure to read the blue Note box at the top of the tutorial. If you did not originally have the Dim display after option available, then it means that it is not supported on your PC. etc...
ran the reg file on my windows 8.1 based tablet and it successfully added "dim display after" to the display power options. however after setting the "dim display after" time, 5 minutes in my case, nothing happens, the screen does not dim. is this feature dependent on setting the "turn off display after" to x minutes? i don't want my screen to ever turn off, i just want it to dim 75% or so after idle for x minutes, my tablet is always plugged in. if i allow the tablet's screen to turn off, the tablet goes into sleep or hibernate mode, depending on the setting, and requires a power button push to waken, i don't want that. any thought or help is much appreciated!
    windows 8 pro
    hp z1
    xeon 1245
    16gb
    gtx 675m
    27"
    several: ssd, hybrid, ide, etc.
    aio
    maxthon
    defender/ mbam pro
Unfortunately, if you did not originally have the Dim display after option available, then it means that it is not supported on your PC. :(
thanks for the prompt reply but i'm a bit confused, i thought the reg "fix" was for those who didn't have the "dim display after" option originally, i.e. that it would give them it, assuming a battery driven pc... if that's not the case, what is this "fix" for? thanks again...
    windows 8 pro
    hp z1
    xeon 1245
    16gb
    gtx 675m
    27"
    aio
    maxthon
    defender/ mbam pro
Nar, it's to be able add or remove it if you already had it by default.
