Power Options - Add or Remove "Dim display after"
  1. #20
    ok, i think? do you happen to know of any third party options that will dim the screen after x amount of time? thanks again, and thanks for the tremendous forum!
  2. #21
    You might see how the free program f.lux may work for you for this. It's pretty good.
    https://justgetflux.com/
  3. #22
    Quote Originally Posted by Brink View Post
    thanks for the suggestion, but it doesn't look to be what i'm after, which is something that will dim the screen x% when the system is idle, and return to full brightness once the screen is touched again, without ever turning off the screen... gonna do some more google searching, there has to be something out there like that... thanks again.
  4. #23
    found a free, simple program - shadenow... so far it seems to be a winner and does just what i need: dims the screen x % after x amount of time, both defined by the user, and returns to full brightness, or wakes up, the moment you touch the screen...
    Shadenow - Download
  5. #24
    Perfect. Thank you for posting back with it.
  6. #25
    Windows 10
    Quote Originally Posted by tprothro1 View Post
    Shadenow - Download
    I've been searching for a solution to this problem (Windows 10 though), and I just wanted to add that this solution won't work (assuming part of the desired goal is power saving). The ShadeNow program "dims" the screen by darkening the color of the LCD. It does not appear to dim the backlight. If one has an OLED screen this may work, but for most of us with backlit LCDs this probably isn't going to achieve the desired result.
    I tested this by exploiting my screens lovely edge lit backlight bleed =P
  7. #26
Page 3 of 3 FirstFirst 123
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You...
How to Add or Remove "When sharing media" in Power Options in Windows The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme. The Slide show power option allows...
How to Add or Remove "System cooling policy" in Power Options in Windows The System cooling policy power option allows you to specify the cooling mode you want to use for your system. Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort. Passive...
How to Add or Remove "Turn off hard disk after" in Power Options in Windows The "Turn off hard disk after" power option setting lets users set to have hard disks power down after a specified time of inactivity is detected. When you set to turn off hard disks after idle, there will be a...
How to Add or Remove "Console lock display off timeout" in Power Options in Windows 8 and 8.1 Console lock display off timeout is the amount of minutes Windows will wait idle with no activity while on the lock screen before timing out and automatically turning off the display. This...
