Power Options - Add or Remove "Dim display after"
  1. #10
    Windows 8.1 Pro 64
    Why don't they have the "dim display after x min" feature in W8.1?
    According to IBM:
    "Dim the display does not display in the edit plan settings. This new behavior is designed for Windows® 8.1. Dimming will be set to occur 15 seconds before display off."
    So is this true? For W8.1, it will automatically dim the screen 15sec before shutting off, but there's no option to set it to dim after a certain idle time?
  2. #11
    Hello Crimson,
    Only for what is in the blue note box at the top of the tutorial in Windows 8.1.
  3. #12
    Windows 8.1 Pro 64
    I don't understand. It just says it won't work if it's not supported by the PC. So it's something built in the hardware? Because the desktop I built is just a normal desktop build. So it's only for something like laptops where the display is integrated into the hardware of the system?
  4. #13
    Correct. Desktops would not have this as an option. Only PCs that have a battery would, but I have not seen this setting available since Windows 8.1.
  5. #14
    stockholm
    windows 8.1
    Can you give a link for a "Add_Dim_Display_After.reg" file download for windows 8.1??
    Oh! I have a Lenovo laptop (brand new one too)
  6. #15
    Hello usawake, and welcome to Eight Forums.
    This tutorial is for Windows 8.1 as well. Windows 8 is just generic for all Windows 8 builds and versions.
    Be sure to read the blue Note box at the top of the tutorial. If you did not originally have the Dim display after option available, then it means that it is not supported on your PC. etc...
  7. #16
    ran the reg file on my windows 8.1 based tablet and it successfully added "dim display after" to the display power options. however after setting the "dim display after" time, 5 minutes in my case, nothing happens, the screen does not dim. is this feature dependent on setting the "turn off display after" to x minutes? i don't want my screen to ever turn off, i just want it to dim 75% or so after idle for x minutes, my tablet is always plugged in. if i allow the tablet's screen to turn off, the tablet goes into sleep or hibernate mode, depending on the setting, and requires a power button push to waken, i don't want that. any thought or help is much appreciated!
  8. #17
    Quote Originally Posted by tprothro1 View Post
    Unfortunately, if you did not originally have the Dim display after option available, then it means that it is not supported on your PC.
    Instead, your display(s) will automatically dim by the percentage set in "Dimmed display brightness" exactly 15 seconds before what is set in "Turn off display after".
  9. #18
    Quote Originally Posted by Brink View Post
    thanks for the prompt reply but i'm a bit confused, i thought the reg "fix" was for those who didn't have the "dim display after" option originally, i.e. that it would give them it, assuming a battery driven pc... if that's not the case, what is this "fix" for? thanks again...
  10. #19
    Nar, it's to be able add or remove it if you already had it by default.
Power Options - Add or Remove "Min/Max processor state"
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You...
Tutorials
Power Options - Add or Remove "USB 3 Link Power Mangement"
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
Tutorials
Power Options - Add or Remove "Slide Show"
How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows You can have a slide show (a rotating series of pictures) as your desktop background. You can use your own pictures or pictures that Windows provides as part of a theme. The Slide show power option allows...
Tutorials
Power Options - Add or Remove "System cooling policy"
How to Add or Remove "System cooling policy" in Power Options in Windows The System cooling policy power option allows you to specify the cooling mode you want to use for your system. Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort. Passive...
Tutorials
Power Options - Add or Remove "Turn off hard disk after"
How to Add or Remove "Turn off hard disk after" in Power Options in Windows The "Turn off hard disk after" power option setting lets users set to have hard disks power down after a specified time of inactivity is detected. When you set to turn off hard disks after idle, there will be a...
Tutorials
Power Options - Add or Remove "When sharing media"
How to Add or Remove "When sharing media" in Power Options in Windows The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or...
Tutorials
Power Options - Add "Console lock display off timeout"
How to Add or Remove "Console lock display off timeout" in Power Options in Windows 8 and 8.1 Console lock display off timeout is the amount of minutes Windows will wait idle with no activity while on the lock screen before timing out and automatically turning off the display. This...
Tutorials
