IE Security Zones - Enable or Disable Level Settings
How to Enable or Disable Changing Security Zone Level Settings in Internet Explorer
Zone security in Internet Explorer is a system that enables you to divide online content into categories, or zones. You can add or remove websites from the zones, depending on your level of trust in a website. Users can set default or custom level settings per security zone.
This tutorial will show you how to enable or disable all users to be able to change the Internet, Local intranet, Trusted sites, and Restricted sites security zone level settings in Internet Explorer.
This could be handy to set the security zones to "default level" or a "custom level" settings you like, then disable it to prevent any changes by users.
EXAMPLE: IE Security Zone Level Settings Enabled and Disabled
Enable/Disable Changing Security Zone Level Settings using REG File
2. To Enable Changing IE Security Zone Level Settings
Enable_Changing_IE_Security_Zone_Level_Settings.reg
3. To Disable Changing IE Security Zone Level Settings
Disable_Changing_IE_Security_Zone_Level_Settings.reg
6. If prompted, click/tap on Run, Yes (UAC Windows 7/8) or Continue (UAC Vista), Yes, and OK.
Enable/Disable Changing Security Zone Level Settings using Group Policy
NOTE: This option for using group policy is only available in the Vista Business, Vista Ultimate, Vista Enterpise Windows 7 Professional, Windows 7 Ultimate, Windows 7 Enterprise, Windows 8 Pro, and Windows 8 Enterprise editions.
1. Press Windows+R to open the Run dialog, type gpedit.msc, and click/tap on OK.​
2. If prompted by UAC, then click/tap on Yes (Windows 7/8) or Continue (Vista).
3. In the left pane, click/tap on to expand Computer Configuration, Administrative Templates, Windows Components, and open Internet Explorer. (see screenshot below)​
4. In the right pane of Internet Explorer, double click/tap on Security Zones: Do not allow users to change policies. (see screenshot above)​
6. To Enable Changing IE Security Zone Level Settings
A) Select (dot) Disabled or Not Configured, click/tap on OK, and go to step 8 below. (see screenshot below step 7A)​
7. To Disable Changing IE Security Zone Level Settings
A) Select (dot) Enabled, click/tap on OK, and go to step 8 below. (see screenshot below)​
8. You can now close the Local Group Policy Editor window if you like.​
  • Disable_Changing_IE_Security_Zone_Level_Settings.reg
  • Enable_Changing_IE_Security_Zone_Level_Settings.reg
Hi,
I have not had success with Option 1. I can't do Option 2 since I do no have Win8 Pro.
Have there been any issues using option1?
Thanks,
Steve
    Toshiba
    Core i7
    ie11
Hey thanks for the quick reply!
I get the nice warning that my registry will be edited:
Then I get the message the registry was successfully edited:
But when I go to internet options to adjust security, custom level is still grayed out after a restart of IE and reseting the laptop:
Thanks,
Steve
    Toshiba
    Core i7
    ie11
I don't understand, I want to Enable Changing Security Zone Level Settings in Internet Explorer just as the title implies.
Thanks,
Steve
    Toshiba
    Core i7
    ie11
True, but your last screenshot shows some other policy or registry value is set for this instead. If you have a restore point available dated before this happened, it'll be a quick fix.
Hi @Brink, although your post is almost 4 years old I have a question. Is there another way to deinstall the above registry key? Other than using a restore point? I installed the key in a windows 10 (virtual) pc, but I want to undo it.
UPDATE: I already found out how to change it.
    Windows 10
:thumbsup:
