ISO Images - Mount or Unmount
How to Mount or Unmount ISO and IMG image in Windows 8 and 8.1
Windows 8 supports native ISO and IMG mounting and unmounting.
This tutorial will show you how to mount or unmount an ISO image in Windows 8 and 8.1.
You are unable to edit an ISO image using Windows 8.
To Mount an ISO or IMG Image File in Windows 8
1. Do step 2 or 3 below for how you would like to mount the image file.​
2. To Mount an ISO or IMG File using Context Menu
A) Right-click or press and hold on the .iso or .img file, and click/tap on Mount, and go to step 4 below.​
OR
B) In File Explorer, select (highlight) the .iso or .img file that you want to mount, click/tap on the Manage (Disc Image Tools) tab, click/tap on the Mount button in the ribbon, and go to step 4 below.​
3. To Mount an ISO or IMG File using PowerShell
A) Open PoweShell, type the command below, press Enter, and go to step 4 below. (see screenshot below)​
Mount-DiskImage -ImagePath "Full path of ISO file"
Substitute Full path of ISO file in the command above with the actual full path of the image file's location within quotes.
4. A new window will pop-up showing the opened mounted ISO or IMG image and it's contents.​
5. You could also double click/tap on the mounted image (DVD drive) in the This PC (Computer) window in File Explorer to open and see the contents of the .iso or .img file.​
To Unmount an ISO or IMG Image File in Windows 8
1. Do step 2, 3, or 4 below for how you would like to unmount (eject) the image file.​
2. Restart the computer to unmount all mounted ISO, IMG, VHD, and VHDX files.​
OR
3. In the Computer window in File Explorer, right-click or press and hold on the mounted ISO or IMG drive, and click/tap on Eject.​
OR
4. Open an elevated command prompt, type the command below, and press Enter. (see screenshot below)​
mountvol DriveLetter: /d
Substitute DriveLetter in the command above with the actual drive letter of the mounted image file.
Nice tut, thanks.
    76~2.0
    Intel Core i5-3570K 4.6GHz
    GIGABYTE GA-Z77X UD3H f18
    Onboard VIA VT2021
    22" LCD Dell SP2208WFP
    1680x1050
    Corsair HX650W
    Cooler Master Storm Scout
    Logitech Wave
    CM Sentinel
    Abysmal
    Opera Next
    Desktop: eSATA ports,
Native mounting? Sweet, love it!
    Windows 7 Professional x64
    Me? Model number... seven? two?
    Intel Core i7-5820k
    ASUS X99-A
    16GB Kingston HyperX Fury DDR4-2400 (4x4GB)
    EVGA Geforce GTX 970 SC
    Samsung 850 EVO 250GB x2; Seagate Barracuda 3.5" 7200RPM 2TB; Toshiba 2.5" 750GB 5400RPM
    Corsair RM750
    Fractal Design Define R5
    Noctua NH-D15
    Yup, it's a computer!
What a cool new feature! Im happy with Win7, but looking forward to Win8!
    Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
    Homebrew PC - "Alpha_Dawg"
    Intel Core 2 Quad - Q9550 - 2.83GHz stock - OC'd to 3.6GHz
    Gigabyte EP45-UD3P
    4GB DDR2 800MHz (PC6400) OCZ Reaper
    Nvidia GeForce GTX 460
    Asus Xonar DX
    Samsung SyncMaster 2333HD
    WD Caviar Black 750GB/7200RPM/32MB cache
    WD Caviar Green 2.5TB/5400RPM/64MB cache
    WD Caviar Green 2.0TB/5400RPM/64MB cache
    PC Power & Cooling Silencer 750
    Gigabyte 3D Aurora
    Case is Air - 5ea. 120mm fans (mix of Arctic and Xigmatec)
    50 mbps down/5 mbps up
    AVerMedia - AVerTVHD G2 Dual Tuner Card
Can you unmount from the command line? I mounted an iso from a network drive and must have lost connection for a moment. Now everytime I right or left click explorer stops responding.
    windows 8 consumer preview
    RM Slate 100
    Intel Atom N450
    2 GB
    intel GMA 3150
    32GB SSD
had to cold boot the tablet to get it to let go of the mount.
    RM Slate 100
    Intel Atom N450
    2 GB
    intel GMA 3150
    32GB SSD
I find mounting an iso as simple as double-clicking the iso file in Explorer, and the new virtual CD/DVD drive opens in the Explorer window. Right click the virtual CD/DVD drive and select eject to unmount it. The mount is not persistent and will not remain on the next reboot.
If you need to reconnect to the iso regularly, a shortcut to the iso file on the desktop will work, but pinning the mounted virtual CD/DVD drive to the taskbar will not.
If you wish the virtual CD/DVD to be available when Windows opens, copy the shortcut to the iso file to your startup folder:
C:\Users\<username>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
You can then pin the Virtual CD/DVD to Start if you wish.
What is more, VHD files mount with a double-click too!, which makes playing with virtual drives easier than ever. Here again, Eject on the right-click menu unmounts the VHD. The VHD can also be automatically mounted from the Startup folder when Windows 8 opens.
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
Is there a way to mount "bin" files?
    Windows 8 CP
    I7 -2600k @ 4.8 ghz
    AZROCK Z77 Extreme6
    8gig Corsair Dominator 1600 DDR3
    Gigabyte GTX 680
    Onboard
    Dell Ultrasharp U3011
    2560 x 1600
    1 x Crucial M4 256gb SSD
    2 x 1tb Western Digital Caviar Black
    1 x 2tb Western Digital Caviar Green
    1 x 2Tb Samsung Story USB 3
    1 Ready NAS NV+ with 4x2Tb Drives
    Enermax MAXREVO 1350 Watts
    Antec Lanboy Air with NZXT Sentry LXE Controller
    Antec Kuhler 920
    Roccat Isku
    Roccat Kova+
    12000 Kb/s
    Brother 6490CW Multifunction Printer
    Brother 2170W Laser Printer
    Fritz Box 7390 Modem / Router
    Logitech Webcam 500
    Logitech G25 Racing Wheel
    XBox 360 Controller
    Logitech Z4 Speakers
    WD TV Live
I think "bin files" cover so many types of binary data you wouldn't have a hope of safely opening them except by the program that is specifically intended to handle it's own "bin files".
In the context you mean, Magic Iso I believe does open these DVD images. Google bin files and there's plenty of relevant stuff.
Windows does not handle missing source image files for the mounted volumes very gracefully yet - it needs to be as clean as removing a removable disk or usb device, not hang your system searching for it. It's the same with missing network shares sometimes. We've used floppy drives in PCs, and the subst command for nearly 30 years, it's about time Microsoft got this right.
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
It's the same with missing network shares sometimes. ...it's about time Microsoft got this right.
Hallelujah, praise the truth. Preach. Church. Amen and all the other feel good stuff that people say when there's an epiphany.
And here I thought the issue was something senseless only applicable to my administrating. I have found registry edits at times that helped but no solid perfect/reliable way.
Windows 8 here has Windows Explorer hang issues when a mapped drive to a turned off laptop is not available. Even just opening Winrar takes about a full minute. Once I rid the unavailable share, issues resolve immediately.
I should Wireshark it to see if anything I can figure out is going on.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
It'll only go when the basic devices don't depend on being enumerated in the registry. That's why I go on about C: drives. look how simply 'nix does it - everything's a file - not entries in a non-relational, obscurely structured database with unintelligible codes nested 20 deep.
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
I don't have a Manage tab on File Explorer/Windows Explorer. Does this require hardware virtualization to work? I don't have it since this is a Intel P4.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
Thanks Shawn, that was it. The default was set to IsoBuster. Restored default and it works a treat. I like it!
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
You're most welcome Rich. I'm glad to hear all is well again. :)
Hello Balubeto,
You could mount an ISO or IMG file using the command below in PowerShell.
Mount-DiskImage
To unmount the ISO or IMG file, you could use the command below in an elevated command prompt. It would be the same as ejecting the drive.
I've updated the tutorial to add this to help.
Hope this helps, :)
Hello Balubeto,
Mount-DiskImage
Hope this helps, :)
It is possible to do it even with a command not Powershell?
Thanks
Bye
You could type powershell in a command prompt first, press Enter, then use the command below in the command prompt. It won't work in one line though.
