Solved XFX 7950 (possibly) causing black screens + loud fan noise
27
Since yesterday, my graphics card has been starting to go to black screens and emit loud fan noises. I suspect it may be due to a recent update regarding something about WDDM 1.3 since that too was installed yesterday.
I have managed to play The Sims 3 at max settings today without the problem, but the problem kept recurring after that. Even with non-intensive activities like watching YouTube brought my desktop to a screaming halt, literally.
What do you think is causing all of this?
    Windows 8.1 (64-bit)
    PC Specialist
    AMD FX-8350 @ 4.00 GHz
    Asus M5A97 R2.0
    16GB Kingston HyperX Genesis @ 1600MHz
    XFX Radeon 7950 3GB Core Edition
    LG M2780D
    [email protected]
    Primary: 120GB Kingston HyperX (SSD)
    Secondary: 2TB Western Digital 20EZRX
    Corsair TX750M
    PC Specialist Trailbreaker 7206B
    Corsair H60 Hydro
    Logitech K260
    Logitech M210
    BT Infinity (fibre optic) @75Mb/s
    Firefox 28
    Norton 360
    WiFi: Qualcomm Atheros AR938x
USA
118
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
27
That's what I suspected and I think it's what's causing all this. However, I can't seem to find it under 'Installed Updates' despite it being in the update history...
    PC Specialist
    Asus M5A97 R2.0
    LG M2780D
    [email protected]
    Corsair TX750M
    Corsair H60 Hydro
    Logitech K260
    Logitech M210
    Firefox 28
    Norton 360
USA
118
Next best option is to use "system restore", if turned on, you cant revert your system back to a date in time before the the update.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
27
Done that, and my system hasn't crashed so far watching YouTube. If Sims 3 works, then I my problem should be solved.
    PC Specialist
    Asus M5A97 R2.0
    LG M2780D
    [email protected]
    Corsair TX750M
    Corsair H60 Hydro
    Logitech K260
    Logitech M210
    Firefox 28
    Norton 360
USA
118
Hey hey....glad to hear it.
Next time you get MS updates, just make sure to go through them all carefully and check the one's you need and hide the ones you don't.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
