Workaround for metro apps not launching and enabling side-by-side apps
matejdro
51
Minimum resolution for fully working Metro UI is 1024x768. But most current touch devices out there have resolution of 1024x600 or smaller, which means that we could not enjoy testing new metro UI.
Fortunately, Intel added a feature into their drivers that allows you to get bigger resolution on same screen. Of course enabling that means odd looking screen (due to aspect ratio differences) and slightly reduced performance. But I guess It's OK for testing until we get something better. This works only for Intel graphics, so ION or any other non-intel graphics users, you are out of luck. Let's start:
1. Install latest drivers for your graphics. Windows 8 may already have latest drivers installed, but it's better to play safe and install latest drivers. Of course pick Windows 7 ones, since there are no drivers specifically for Windows 8 available yet.
2. Swipe left from right side of the screen to get little menu. Select "Search".
3. In search menu select "Apps" and type "regedit" (without quotes) into search box.
4. On left side you should get one result with text "regedit". Tap on it. If you get any UAC dialogs, accept it.
5. Registry Editor will open. Go to Edit --> Find and enter "Display1_DownScalingSupported" into search box. Make sure that all 3 checkboxes are checked (Keys, Values and Data). Start search.
6. After some seconds of searching, it should find an entry. On the right pane, you should see Display1_DownScalingSupported entry. Double tap on it, enter 1 under "Value data" and press OK.
If you are using Consumer Preview, skip points 7-9. It does not work anymore.
7. On the left pane scroll to the top and then find HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\ImmersiveShell\AppPositioner (tap on arrow next to HKEY_CURRENT_USER, then on arrow next to Software etc.)
8. If you see "AlwaysEnableLSSnapping" on the right side, double click on it. Otherwise right click on the pane (hold your finger until you see square appear around it) and select New --> DWORD Value. Name the new value "AlwaysEnableLSSnapping" (without quotes) and double click on it.
9. Like in step 6, enter 1 under "Value data:" and confirm.
10. Reboot your computer.
11. Go into display options. You should now see new resolution options. Select any resolution that is 1024x768 or higher and you should get fully working metro UI :)
    Windows 7
vrosa
Tech Addict
Interesting. Thanks for posting :)
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
Avalon
Away for a bit
Australia
584
This should be very handy for all those users that want to get 8 working on a tablet. Great post! :)
    Windows 8 Dev Preview x64
    i7 950 3.06GHz
    Asus Rampage III
    G Skill 4GB DDR3 2000MHz
    Nvidia GTX570 1.25GB DDR5
    Antec ATX TruePower 750W
    Antec Lanboy Air Red
JaidynM
BSOD Kernel Dump Analyst
Gold Member
Very nice. ;)
    Windows 7 Ultimate x64/Windows 8 Consumer Preview x64/Ubuntu 11.04
    Custom Build
    Intel Pentium Dual Core E6700 3.2GHz
    ASUS P5G41T-M LX
    Strontium 8192MB DDR3 1333Mhz
    msi GeForce N560GTX-M2D1GD5 1GB
    Realtek HD Audio
    CHIMEI CMV 221D 22"
    1680x1050
    Seagate 3.5'' 2TB HDD/WD Elements External 1TB HDD
    SHAW Viper-1500w Gaming PSU
    Black eMaxx ATX Mini Tower Case
    Microsoft Wireless Keyboard 1000
    Microsoft Wireless Optical Mouse 2000
    100GB @ 4.76Mbps
602
Great post!
    WCP
    HP
    [email protected] 4.9 Hz
    64 gig
    Nvidia 9600
    integrated
    laptop
    1440x900
    300gig internal and a bunch ext
    not much
    Built-in
    Logitch Anywhere Mx wireless mouse
    50 down 1.5 up
noelian13
55
i tested that on my aspire one d255 netbook but no luck piano opens sits in there for a while....then screen goes green nothing happens then i tap touchpad green screen is gone and back to start menu idk why.... i have updated my media controller driver though :(
    Windows 8.1 Build 9600
    Toshiba,Acer(2 notebooks)Asus G1S
    Intel i5 2400 @3.1 ghz/i3 4th gen
    GA-Z77M-D3H
    8GB
    Sapphire, AMD Radeon HD 6570
    1360x760
    40mbps
brummyfan
Birmingham
1,487
I did have the same problem and found out the RMClock program was the cause, I used the program for undervolting, while I was using it I couldn't play Piano, you could try disabling programs one by one and find out which program conflicts with Piano and let us know.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
noelian13
55
#8
i just solved my problem hehe :D i just logged in using my live id account and piano worked :D
    GA-Z77M-D3H
    8GB
    1360x760
    40mbps
mikedl
Removed by request
520
#9
Nice!
I hadn't tried the Piano App recently because, when I first installed Win8 8102 DP back in September, it didn't work.
I have, in the interim, acquired a Live ID but didn't bother to check out the Piano App again ... until reading your post.
It does, indeed, now work. :)
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    Laptop 17", Gateway 20"
    1440x900 (x2)
noelian13
55
#10
Nice!
glad i helped somehow :)
    GA-Z77M-D3H
    8GB
    1360x760
    40mbps
2Triangle
I can't find "Display1_DownScalingSupported" anywhere through regedit... It says Finshed searching through the registry.. And "Display1_DownScalingSupported" is still not found. Help?
    Windows 8 Developer Preview x86
noelian13
55
#12
First try installing your graphics driver im in acer notebook so you might wanna look it in your notebook manufacturer website and find a graphic driver install it...then try searching in the registry again
    GA-Z77M-D3H
    8GB
    1360x760
    40mbps
noelian13
55
#14
okay your welcome :)
    GA-Z77M-D3H
    8GB
    1360x760
    40mbps
1
#15
i cannot find "AppPositioner" after "ImmersiveShell"....why??...i follow ur insrtuction n try search it many times but same result...:(
    Windows 7 ( 64bit )
    Asus
    Intel Core i3
    Asus P8H61-M-LX
    Kingston 4gb
    Asus Nvidia GT 430
KriLL3
7
#17
Seems broken in release preview, my screen remains black, tried it a bunch of times on x86 and x86-64, inputs work, machine has clearly booted etc, but from the boot logo on the screen remains pitch black.
Anyone managed to get it to work on RP? It's a bad solution anyway imo, makes the screen look odd, I wish there was a more clear-cut way to just force metro apps to work, instead of making the screen the wrong resolution.
    Win7 Ulti, Win8 CP
    Mine
    Q6600
    Rampage Formula
    8GB DDR2
    Asus 6970
KriLL3
7
#19
I stopped using that, because I don't use metro apps anyway (they are very inferior to desktop alternatives).
Agreed, except on a tablet, which is what I have.
    Win7 Ulti, Win8 CP
    Mine
    Q6600
    Rampage Formula
    8GB DDR2
    Asus 6970
