Wireless network card not finding my wireless network ?
GhostDog
The Keeper
My wireless card in my Compaq Presario works fine and Windows 8 detects it and said it was compatible. For some strange reason though it's not working in Windows 8. It hasn't detected my wireless network. Currently I am connecting using a cable.
The card is Qualcomm Atheros AR5007 802.11b/g WIFI Adaptor.
I am trying to do a Google search on this issue, is it me but is this device not compatible with Windows 8 despite Window 8 saying so? I have updated the drivers through Windows Update, but it still can't find my Wireless network even though Windows 7 did originally before my upgrade.
    Windows Eight
GhostDog
The Keeper
I have done a diagnosis and here's what it says (if this helps)
Windows Network Diagnostics
Publisher details
Issues found
Problem with wireless
adapter or access point
Problem
with wireless adapter or access point
Not fixed
Investigate router or access point issues
Failed
Reset the wireless adapter
Completed
Issues found
Detection details
6
Problem with wireless adapter or
access point
Not fixed
issues
Failed
If you're
connected to a hotspot or domain network, contact the network administrator.
Otherwise: 1. Unplug or turn off the device. 2. Once all of the lights on the
device are off, wait at least 10 seconds. 3. Turn the device back on or plug it
back into the power outlet. To restart a router or access point that has a
built-in battery, press and quickly release the Reset
button.
Completed
Network Diagnostics Log
Detection details
Diagnostics Information (Wireless
Connectivity)
Details about wireless connectivity diagnosis: Information for connection being diagnosed Interface GUID: ce41e296-363d-406b-a232-35fcd0cc7e33 Interface name: Atheros AR5007 802.11b/g WiFi Adapter Interface type: LegacyConnection incident diagnosedList of visible access point(s): 0 item(s) total, 0 item(s) displayedConnection History
Connectivity)
Details about wireless connectivity diagnosis: For complete information about this session see the wireless connectivity information event.Helper Class: Auto Configuration Initialise status: SuccessInformation for connection being diagnosed Interface GUID: ce41e296-363d-406b-a232-35fcd0cc7e33 Interface name: Atheros AR5007 802.11b/g WiFi Adapter Interface type: LegacyResult of diagnosis: Problem foundRoot cause:This computer cannot connect to wireless networksThe wireless network adapter on this computer is not working properly.Detailed root cause:This computer's wireless network adapter is not readyRepair option:Resetting your wireless network adapterThis will disable and then enable the network adapter "WiFi" on this computer.
Other Networking Configuration and
Logs
Collection information
Computer Name: SHADOWDAN-PC
Windows Version:
6.2
Architecture:
x86
Time:
30 October 2012
21:18:30
Publisher details
Detects problems with
network connectivity.
Package Version:
1.0
Publisher:
Microsoft Windows
    Windows Eight
