Solved wired connection prevents wireless connection
47
hello
when i connect my hp probook 4520s to my sony vpcyb4ajg with Ethernet cable on my Hp wireless disconnects and can not be connected until i disconnect lan cable. but on my sony i have both wired and wireless connections simultaneously
hp:win8 x64 realteck Ethernet and atheros wireless
sony: win 7 x86 atheros Ethernet atheros wireless
    win 8
    Hp probook 4520s
    Ci 5
    radeon mobility hd 4500
DMHolt57
Austin, Texas
1,252
There is a setting to disable in the group policy editor, minimize the number of connections, under Administrative Templates, Network, Network Connections.
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
47
there's not such a setting there
neither in user config nor in computer config
would you be a dear and give more detail?
thanks
    win 8
    Hp probook 4520s
    Ci 5
hello
It may look like the Sony is using both connections but it's not, it's using the wired one.
The analogy that well if one machine is doing this then why isn't the other doesn't really work with computers.
In fact my own machine maintains a wired and wireless connection but the wireless only works if I unplug the wired connection.
You can be connected to both but the wired connection will win out every time.
If you really want the machine to use more than one connection you can try the connectify dispatch software, it still only chooses the best connection to use at any given time.
Connectify - Turn your PC into a Wi-Fi Hotspot and Get Faster Internet
There is also a Group Policy setting for using two connections but I'm not sure how it works. A while back I took the time to look up this policy just in case somebody wanted to try it.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
davehc
Denmark (But English)
1,150
Yes. I have the same situation as Chev, on a Dell laptop. Even through the docking station, it shows both wireless and ether as working, but only the Ethernet is, in fact, operational. Quite an advantage through a docking station, I disconnect and am , unbroken, back on wireless.
    Use several different computers during a day, so specs are irrelevant.
47
to prevent any misunderstanding let me describe the situation in other terms.
i have an adsl wireless modem, both laptops connect to internet through this modem via wireless connection. some times when i need to transfer large amount of data between to laptops i connects these two by a ethernet cable. after connecting two laptop to each other sony still has internet connection but hp is disconnected!
also in notification area sony shows wireless icon connected with internet access but hp shows wired icon with red warning which says no internet access.
so i guess it is impossible for sony to access internet through hp! and also it doesn't seem to be normal and hp has a problem in configs!
    win 8
    Hp probook 4520s
    Ci 5
47
i just unchecked lan/wlan switching in bios setting and built in device section. now everything is working nice and smooth.
    win 8
    Hp probook 4520s
    Ci 5
