Windows 8 Theme problem (My first Post)
R
robc163
Guest
Hey guys so I recently got Windows 8 Pro and I love it but I got a problem
When I set themes my parts of my metro UI disappear and I have to restart the computer to make it go back to normal
I thought this was a bug in Windows 8 at first as the same thing happened to me when I was using the consumers preview and the release preview but I found out today that it's just my computer as my friend has Windows 8 pro and can set themes without a problem
Here are some screenshots of before and after I apply a different theme
Before:
After:
As you can see my side bar loses 2 buttons and the metro bar on the side almost goes completely invisible apart from the top part
I also notice other things disappear like the design on my start menu (Background pattern)
What would any of you recommend
Thanks for all answers
Hopachi
Polyhedric Stellation
Orbiting the Moon
Welcome to EF!
Hard to tell what's wrong.
Is that an original (native) theme or are you using something custom that needs patching system files?
If that's a native theme, maybe updating the graphics driver may help.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
R
robc163
Guest
Hey the first theme before change was one I downloaded from the Windows Website and was also one I used on Windows 7 however I have tried the same thing using only Windows 8 themes and the same thing happens
the second theme is the standard default theme for Windows 8
I will have a look for a updated version of my graphics driver
Thanks
Hopachi
Orbiting the Moon
Thanks
Ok. The themes from Windows Website are safe. This seems not to be theme-related but something to do with graphics.
Try the latest driver for your chipset and see if it helps.
Good luck
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
R
robc163
Guest
So I updated my graphics driver and my chipset drivers and have had no success still so any other suggestions
Hopachi
Orbiting the Moon
Sorry to hear that.
Hope you find a solution.
I also use Win8 x64 but didn't see this glitch ever.
As long as the letters are visible that's not critical.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
