Windows 8 Problem with programs and DVD Drive
Chaize
I installed Windows 8 on my laptop like 5 days ago, everyone worked fine and dandy there but somehow now most of my programs won't launch but i can see it in Task Manager, my DVD drive won't open when i try to eject it physically, when i try to right click and eject it in My Computer, it freezes immediately and doesn't recover so i'd have to end it via TM.
But this is what i don't understand, after i put my Laptop to sleep by pressing briefly on the power button, when i turn it on again, the DVD drive then opens after the long time i tried to open in while using Windows, i then login and the program.s that wouldn't open like Origin and iTunes would be opened after logon..
Windows Media Player also freezes when i use it to open music files and play as it is the default player, sometimes it plays the music but it won't let me pause or change volume, sometimes i won't play at all and it'd just freeze..
And sometimes when i try to restart, the system hangs and won't actually restart leaving me to hold down and press the power button to shut-down the system :[
this is frustrating and i'm not sure what the cause of this is.. I need help :[ I'm almost regretting upgrading to Windows 8..
    Windows 8 Proffesional 64 bit
    Acer Aspire 5560 Laptop
    AMD Quad Core A6-3420M 2.4GHz
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    Dolby Advanced HD Audio v.2
    15.6 inch HD LED Display| 19 inch HP Monitor
    1366x768|1440x900
    500GB S-ATAII HDD + Seagate External 1TB
    6 cell Li-on battery
    Fan
    Laptop Keyboard
    Trackpad|Logitech Lightweight USB Mouse
    Average
mdmd
Closed as requested
Hello Chaize. Welcome to the Eight Forums.
Awesome system. ... reluctant to ask. Did you install on top of a previous version of Windows?
My suggestion, IMO, do a clean install on unallocated space.
    Server 2012 / 8.0
    Intel i7 QuadCore 3770k
    Asrock Extreme 4
    16GB Crucial Ballistix
    intel embedded gpu
    Sound Blaster Z
    AOC / Westinghouse
    Plextor pcie msata
    Rosewill Silent Night 500W Fanless / PicoPSU
    open bench - no case enclosure
    Silverstone HEO2 Passive Silent
    logitech washable K310
    logitech wired
    ie / maxthon
    Totally silent. No fans at all.
Chaize
Thanks :'D And yes, i installed on top of Windows Release Preview, after installed it everything was fine no freezes or anything, but after a few Windows Updates, i started experiencing this problem..
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    1366x768|1440x900
    Fan
    Laptop Keyboard
    Average
FuturDreamz
Spacemonaut
try using device manager to manually re install drivers for your optical drive?
    Asus Tansformer Book Flip TP500LN
    Intel i5-4210U
    8GB DDR3 SDRAM
    Nvidia Geforce GT 840M
    15" Touchscreen
    1366 x 768
    1TB Hybrid
    Microsoft Wireless Mobile Mouse 4000
Chaize
I've done that before but still no luck. :[
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    1366x768|1440x900
    Fan
    Laptop Keyboard
    Average
theog
Gold Member
For your DVD drive
Try this (1):
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
Fix problems with CD or DVD drives that can
The CD drive or the DVD drive does not work as expected on a computer that is running Windows Vista
Try this(2):
1) Shut down PC.
2) Physically disconnect the CD/DVD Drive.
3) Reboot to Windows with NO DVD drive.
4) Shut down PC.
5) Physically reconnect the CD/DVD Drive.
6) Reboot to Windows with DVD drive.
7) Check Device status.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
Chaize
I tried your method theog, just before logon, i pressed and it ejected, but after the desktop loaded, it won't open...
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    1366x768|1440x900
    Fan
    Laptop Keyboard
    Average
Chaize
bump
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    1366x768|1440x900
    Fan
    Laptop Keyboard
    Average
Chaize
Anyone? ;[
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    1366x768|1440x900
    Fan
    Laptop Keyboard
    Average
Chaize
That is not my method.
No i physically disconnected and booted into Windows without DVD, i reconnected it again and booted, it was stil visible and clear in device manager..
    AMD Aspire 5560
    8GB DDR3 RAM
    AMD Radeon HD 6520G
    1366x768|1440x900
    Fan
    Laptop Keyboard
    Average
brummyfan
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
