Windows 8 D-drive Problem, Tried Everything PLEASE HELP!!
JamesClark1991
Really hope someone can help with this, it's driving me INSANE. I've tried everything I can think of.
I've got Windows 8 consumer preview installed on my C-drive (240gb SSD). I also have a 2.5" Toshiba HDD (pulled out of an enclosure) set as my D-drive used just for storage (games, photos, videos and music files).
Both C and D drive are healthy and have been benchmarked and tested for errors so it must be a setting on the OS or something similar.
My C-drive has no problems whatsoever. D-drive however is suffering a problem, whenever I double click a folder e.g. a MP3 album nothing happens for about 4-6 seconds.... THEN it will open the folder after the 4-6 second delay. It's the same with everything on D-drive. When I'm downloading something to D-drive the drive becomes almost in-accessible because of a performance slowdown. I tried playing Skyrim whilst downloading a file and Skyrim was so choppy it was unplayable. Never had problems like with a hard drive before, I don't know what the problem is :s
Sometimes it's fine though, I booted up yesterday and my music folders were opening snappy like normal. It comes and goes irregularly, I can't see a pattern of slowdown it's completely random.
PLEASE HELP. IT'S DRIVING ME INSANE :(
    Windows 8 Consumer 8400
    i5
    8gb
lmod
Are your Power Options set to turn off your HDD (in Advanced Settings)? The delay could be the time it takes for the drive to spin up.
    Windows 8.1 PRO with Media Centre Upgrade x64
    Self built
    Intel i5 3570K
    Asus P8Z77-V
    16GB
    Gigabyte GeForce 650Ti+ Gigabyte GeForce 210
    Creative X-Fi Elite
    2 x Samsung SMS24A50 / 1 x SamsungXL20
    2 x 1920 x 1200 / 1 x 1600 x 1200
    Intel SSD 240GB;
    Hitachi HDS721010DLE630
    Seagate ST31000524AS 1 TB
    Samsung HD103SJ (1TB)
    Crucial 128GB m4 SSD
    Corsair 600W
    CoolerMaster Storm
    Air - Fans
    Microsoft 7000
    Microsoft 7000
    Very variable !
    FF, Chrome, IE
    Vipre Internet Security
besb
Hi James Clark;
I had a similar problem type of problem when on occasions the system went into slow motion.
Checking a gadget I had installed showed considerable cpu activity and constant disk activity. I opened task manager and no process appeared to be consuming the amount of cpu activity in use. Checked the tick box at the bottom to show processes from all users and it showed up as Windows Indexing service. i.e it found a new drive had been mounted and was indexing it for rapid searching. If the drive was dismounted and the system rebooted no go-slow. Finally I just let it get on with it and index a 3TB drive.
I am not saying this is the problem but it may be worth checking.
BesB
    xp , 7Pro, 8RP, Android phone, Tablet
    Custom
    q6600@3Ghz, amd 965 etc etc
    gigabyte
    8gb per
    gts450 ,560gt etc
    3xsamsung 24in
    3, 1920x1200
    To many! spread across 4 desktops,3 laptops 1 netbook
    ssd, sata 3's ide etc
    Hyper Modular 600W
    lian li
    artic
    60Mb
    Basically the house has 4 desktops 3 in the study + the wifes,
    3 laptops 1 netbook 2 android tablets 2 android smart phones
    and ipad and iphone
