Solved Windows 8.1 eval ISO problems / activation problems
pricetech
Tennessee USA
69
I first downloaded the Windows 8.1 Eval ISO last week when it was introduced. I have since downloaded it several times, both with and without the downloader, on more than one computer.
The ISO won't mount. The error just says "sorry, the file won't mount".
A couple of times the filename retained the ".part" filename extension.
I was able to burn the ISO to DVD and install it, but it says it's expired.
Surely I'm not the only one, but I can't seem to find a solution. Anybody ???
Joe
    Constantly changing hardware.
Ztruker
If it has .part then the download did not complete.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
alphanumeric
slightly off center
Gold Member
As far as the activation problem goes, its a trial, your not supposed to keep reinstalling it. Once the 90 days is up your required to buy a legal version of move on.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
alphanumeric
slightly off center
Gold Member
But I just got it. It hasn't even been out for 90 days.
OK, I misread your original post, the multiple downloads had me thinking you had already downloaded and installed it one or more times. Check your BIOS's date and time setting.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
pricetech
Tennessee USA
69
Date and time are correct. I've been watching that extra close lately since I recently fat fingered the date in BIOS and couldn't activate because of it.
pricetech
Tennessee USA
69
#8
UPDATE;
I booted to Puppy Linux on live USB and downloaded again. This time I appear to have gotten a clean download because I was able to copy it to a USB drive and install from it, two computers in fact. Sadly, I still get the "expired" message on both.
As far a licencing goes, we're licensed. I just don't want to waste activations playing "Mad Scientist". That's what demos are for.
Maybe I'll just use the Server 2012r2 demo. It has a key.
Joe
alphanumeric
slightly off center
Gold Member
#9
Well, I don't know what to tell you. I've only ever played around with Enterprise once to setup a Windows To Go drive. I used my full TechNet edition and my TechNet key. I haven't played around with the evale version.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
pricetech
Tennessee USA
69
#10
Solved;
I found a discussion about Windows Update not updating if the computer was booted into Audit Mode, which has become so routine to me I didn't even give it a second thought. However after reading that I decided to try again and go through the OOBE this time.
That worked. It has auto activated just like it should and shows me 90 days.
Maybe this will help someone else, especially mad scientists like myself.
Joe
alphanumeric
slightly off center
Gold Member
#11
There you go. :thumb:
    Asus
    Thermaltake TR 620
    Stock heatsink fan
jimbo45
Hafnarfjörður IS
4,373
#12
Right, but the browser shows the download to be complete.
Hi there
The Browser is telling you lies if the file has the suffix .part -- that means for some reason the download was interrupted.
Download again - the suffix should be .iso
However what is "Boot PC into "Audit mode" -- sounds an interesting option - and what does it do.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
