Solved Window of hard drive appears on boot and start
bunny slippers
Had, and still have installed in machine, an SSD with Windows 7 as OS
Had, and still have, a Western Digital 2 TB external HD attached. It was used as back up for the original set up. This also has the Smart Ware software installed but which I have not used.
Tried a dual boot on a new SSD using Windows 8.1 recently but turned out ot be a pain so I simply installed 8.1 on new disk.
The problem-
When I boot and Windows 8.1 starts, window showing the external hard drive and contents appears. Annoying. How can I stop this?
I am planning to reformat this external storage and redo the back up using the new 8.1 OS and current content of the my other HDD containing our data, will this likely stop the "pop-up" on start?
Thank you for any assistance or ideas.
    Windows 8,1 64bit
    custom build
    Intel Core i7 3820 Quad
    ASUS p9X79 Pro
    Corsair 1600C9 Vengeance
    EVGA GeForce GTX 560 Ti
    Cyberfox
    Avast pro
Hello and welcome to Eightforums ,if I understand you issue correctly ,I think if you go to control panel/auto play /removable drives and check of take no action it might get rid of it .good luck
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Thank you for that simple solution. It appears to have solved the issue. Like I mentioned I am going to reformat the drive and begin again the back up and that may have taken care of the problem but for now.............Tanx a lot!!
    Windows 8,1 64bit
    custom build
    ASUS p9X79 Pro
    Cyberfox
    Avast pro
your welcome ,good luck
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
