Window 8.1 Product Key? A few questions.
4
Hey Guys,
In 'System Information', there's a link that says 'Get more features with a new edition of windows". Clicking that brings up an 'Enter Product Key' page, and it is only at this point that I realize my product key isn't stuck to the bottom of this PC.
So, researching this on Google, I found a product key that Microsoft Released for the Trial:
NTTX3-RV7VB-T7X7F-WQYYY-9Y92F
So, my question is: Will my Windows 8 Product Key work with 8.1 Preview?
If so, I think I would rather dig that up than use a generic key.
If it doesn't, and I need to use this generic key, what happens at the end of the Preview when everyone has the same Product Key.
Will Windows 8 become an Operating System where you'll need to pay for the updated OS after the preview? Ie, paying for and getting a new Product Key?
And last, does anyone know what features entering a product key will actually unlock?
Thanks, Kurt
    Samsung NP350V5C-S0BAU
    Intel i5 3230M
    12GB
    AMD Radeon HD 7600M / Intel HD Graphics 4000
    WD7500BPVT-35HXZT3
vrosa
Tech Addict
Hey Guys,
Thanks, Kurt
Welcome to EF BarkerBlast !
1- You can upgrade from Windows 8 without entering a product key, but for a clean install you'll always need a product key. You can enter the generic key or a key received from MSDN in case you have a subscription. Windows 8 keys do not work for a clean install.
2- At the end of the preview, if you upgraded from a valid Windows 8 install you'll be able to upgrade to RTM without a product key, but you will lose all your apps. If you installed the preview form an ISO or upgraded from a non-activated/illegal copy of Windows 8 you'll need to buy a new key.
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
theog
Gold Member
5,591
Before upgrading Windows 8.1, be sure to make your Recovery disc.
We always assume you have made your Recovery Disks using the OEM manufacturer's Recovery Media Creator app the first day you had your new PC.
& made the Startup Repair CD.
http://www.eightforums.com/tutorials/5132-recovery-drive-create-usb-flash-drive-windows-8-a.html
http://www.eightforums.com/tutorials/2855-system-repair-disc-create-windows-8-a.html
You can use the OEM version of
Deleting the Recovery Partition is NOT RECOMMENDED
Did you make the OEM manufacturer's Recovery Disks?
How to make Recovery disc:
Support - Notebooks NP700Z7CH | Samsung Laptops
How to Order Recovery disc.
You can use the Windows system image.
http://www.eightforums.com/tutorials/8956-system-image-create-windows-8-a.html
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
4
Hey Guys,
Thanks, Kurt
Thanks for your reply, I love this place.
Windows 8 is so different, and i'm learning so much from here. I'm kinda excited (and dreading) to read the tutorials, already so much I didn't know.
My version of Windows 8 came with a new laptop I bought only a couple of months ago. I even bought the pro version before that for my old laptop, so it's not illegal in any way.
I installed from the store, and it just went though the motions, the setup time was painfully slow.
Why will I loose all my installed apps? Is the RTM not an upgrade as such, but more a fresh install?
And I guess my biggest question that i'm still not sure about was that, if I enter a product key where I stated in my initial post, will I get any more features as suggested? Or am I better or just leaving it, and using the system as is at the moment? I'm guessing it might just be a feature that isn't finished, ie there's nothing extra to unlock at the moment, maybe it's something for future trial users that have the option of purchasing.
Thanks again,
Kurt
    Intel i5 3230M
    12GB
    WD7500BPVT-35HXZT3
4
Hey,
I've never been one to do backups. I guess I've never been caught at the fault of the manufacturer. I figure that if i'm formatting the computer/mobile, I don't like the way it is at the moment, so i'm starting from scratch. Why would I want to carry everything over with a backup?
I usually delete the recovery partitions, but due to my current nervousness around Windows 8, I decided to leave it there. And after reading this thread from the first post, it's not going anywhere.
So i'm hoping the recovery partition is enough without the discs. It's the best backup plan I've had in 16 years.
    Intel i5 3230M
    12GB
    WD7500BPVT-35HXZT3
bagavan
bangalore
634
Hey Guys,
Thanks, Kurt
After the final RTM, iso images are released the one can use the original product key (windows 8) for upgrading to 8.1(clean install). I hope I am right.
    Windows 8.1 professional x64 + WMC
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
Mystere
1,925
If you have an OEM copy of Windows, the product key is stored in your BIOS, thus it is no longer necessary to enter a product key. The "Add new features" dialog is for adding Additional features like Windows Media Center. It can also be used to upgrade from Windows 8/8.1 standard to Windows 8/8.1 Professional.
NOTE: I have not tried to upgrade an OEM version to 8.1, so I cannot guarantee that this is the case, but it's how it should be.
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
pparks1
Westland, MI
3,658
#8
If you had 8 pro, it might work. I used a box which had 8, and the MSDN copy of 8.1 was pro, and I had to provide a key.
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
4
#9
I bought 8 Pro for my last laptop, this new laptop had it pre-installed. I'm only assuming I had the CD Key provided to me, usually it's on the bottom of the PC, but it's not there?? All seems to be working fine. I think I'll just leave it as is, and wait till the official release before I go trying any CD Keys.
So just to clarify, I do have a Windows 8 Pro CD Key, but it's not the edition I'm using on this laptop.
Thanks
    Intel i5 3230M
    12GB
    WD7500BPVT-35HXZT3
