Solved [Winamp] Will not save current playlist on W8/W8.1
Ever since my migration to Windows 8.1 I have a problem that got me mind boggling and i just can not seem to solve.
I have already asked this question on the Winamp forums but before we could analyze better there, the forums went down (due to their company merger) . :(
I did a clean installation of Windows 8.1 a few months ago.
Then I installed all my apps and manually migrated settings of all the software i use ( from a Windows 7 image ) . I also did this for Winamp .
Everything works 100% since the installation, but when using Winamp the ' current' playlist which the program automatically creates sporadically will not save!
After opening a random number of times, the playlist disappeared spontaneously thus winamp was started with an empty playlist.
This means i can load my recursive playlist each time i start Winamp ( very frustrating with 50K + mp3's ).
I can not think of any software that is installed on my PC which could affect this situation (I don't use a separate antivir. Just Windows Defender).
What I've done so far:
- Uninstalled Winamp. Removed the settings folder. Reinstalled Winamp.
- No additional plugins / addons or whatever installed for winamp .
- Double checked and forced the read-only flag on the winamp user data folder (to make sure the playlist can be saved/written).
The settings folder is in the following location : C:\Users\<username>\AppData\Roaming\Winamp\
The current playlist is saved as : Winamp.m3u and Winamp.m3u8
Does anyone here have any idea how I can fix this problem?
    Windows 10 Pro
    Custom
    Intel Core i7 4770K
    Gigabyte GA-Z97X-UD7-TH
    2 x 4GB G-Skill RipjawsX 1600 MHz DDR3
    HIS IceQ R9 290X (LC)
    RME Babyface Pro
    2 x Dell U2412M 24" WUXGA
    2 x 1920x1200
    1 x Intel SSD750 PCI-e NVMe SSD 400GB
    4 x Sandisk Ultra Extreme 2 120GB SSD in RAID0,
    2 x Seagate ST4000VN000 4TB in RAID1
    Seasonic X-850
    Lian Li PC-A61 USB 3.0
    CoolIT Vantage PRO
    Logitech G710+
    Logitech G302 Daedalus
    90 Mbit DSL
    It flies. :)
Mr Sardonicus
Chicago IL, USA
203
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
Hmm, thanks for the tip.
I will have to test this for about a week, before i will be able to tell if it might have done the trick.
    Windows 10 Pro
    Custom
    Intel Core i7 4770K
    RME Babyface Pro
    2 x 1920x1200
    Seasonic X-850
    CoolIT Vantage PRO
    Logitech G710+
    90 Mbit DSL
    It flies. :)
Well, sadly this trick does not seem to have helped.
Just fired up winamp again, and boom... playlist is simply gone. :(
Any other suggestions? :)
    Windows 10 Pro
    Custom
    Intel Core i7 4770K
    RME Babyface Pro
    2 x 1920x1200
    Seasonic X-850
    CoolIT Vantage PRO
    Logitech G710+
    90 Mbit DSL
    It flies. :)
Anyone? Please? :)
    Windows 10 Pro
    Custom
    Intel Core i7 4770K
    RME Babyface Pro
    2 x 1920x1200
    Seasonic X-850
    CoolIT Vantage PRO
    Logitech G710+
    90 Mbit DSL
    It flies. :)
Hello there,
Is there anyone who could help me solve this issue? I swear this is driving me insane, because i am used to using Winamp a lot. I still can't believe i am the only Windows 8.1 user who seems to have a problem with this... :(
Is there anyone else who could point me into another direction for more information perhaps? (seeing as the winamp forums have been shutdown).
    Windows 10 Pro
    Custom
    Intel Core i7 4770K
    RME Babyface Pro
    2 x 1920x1200
    Seasonic X-850
    CoolIT Vantage PRO
    Logitech G710+
    90 Mbit DSL
    It flies. :)
I got in touch with Winamp support again.
Turns out i had a scheduled task setup with Ccleaner every other day.
This was actually cleaning up the regular winamp playlist. :S
Anyway, problem solved. :)
    Windows 10 Pro
    Custom
    Intel Core i7 4770K
    RME Babyface Pro
    2 x 1920x1200
    Seasonic X-850
    CoolIT Vantage PRO
    Logitech G710+
    90 Mbit DSL
    It flies. :)
