Win 8 CP not recognizing my built in wireless adapter HELP
olie2012
2
Hi. I recently installed 8 as a dual boot option. Everything looks to be working quite well, except that when i go to settings-wireless, it says no wireless devices and wont recognize any wifi networks. I try to go through troubleshooting but it does not help at all, and remains unable to find any networks. Im guessing it is a driver problem, but i couldn't find and drivers to fix this. I have a Toshiba satellite L775, everything works fine in Win 7. Thanks!
    Windows 7/Windows 8 CP dual boot
GMan
Banned
1,851
Hi there.
Toshiba should have a Windows 7 driver to install.
If not, in device manager, right click then choose Properties. Details tab. Change dropdown to say hardware ids. Copy/paste the results here (no screenshots instead of copy/paste, please.)
32 or 64 bit?
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
It seems like going to Device Manage, Action tab, add legacy hardware, Search for and install the hardware automatically would work. Or it might help to get the driver first from the Toshiba site.
Toshiba Support - Homepage
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
olie2012
2
Hi there.
32 or 64 bit?
im not sure if you mean windows 8 driver to install, but i didn't find one yet. 64 bit. When i look under network adapters in Windows 7 i find my wireless adapter installed and working properly, then in windows 8 its not there. i tried doing the automatic search but it didn't find anything and gave me an option to choose from a list of devices but mine wasn't in the list. still searching the net for an updated driver but so far no luck..
Hi there.
32 or 64 bit?
Long shot but you can try this, open a command prompt, type in set devmgr_show_nonpresent_devices=1 and enter then type start devmgmt.msc and enter.
The device manger should open, click on the view menu and select show hidden devices. Then expand the network adapters and see what's listed. Maybe the nic will show up, if it does delete all entries for it. Then right click on network adapters and select scan for new hardware.
If that doesn't make it show up then shut down the system and unplug the power or charge cord, and remove battery if it's a lap top, and wait 5 minutes. Reinstall battery and power up again and see if the adaptor shows up now.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
GMan
Banned
1,851
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
