Solved Win 8.1Pro will not connect to print server on my network
bz6djs
2
Hi Guys, I have read a number of posts here about networking issues but none seemed specific to my issue... I had a Windows 7 environment and just recently purchased a Windows 8 laptop.. .well win 8.1 Pro to be exact. On all of my windows 7 machines I can ping 192.168.1.199 and get solid response and go to that address in the browser and no issue. On the new Window 8.1 laptop I ping that address and sometimes get 1 timeout with 3 responses... other times it just times out and sometimes I get all 4 replies... The print server has a web interface but I am unable to connect to it at all - is there something I need to set in Win 8?
C:\Users\Ron>ping 192.168.1.199Pinging 192.168.1.199 with 32 bytes of data:
Reply from 192.168.1.199: bytes=32 time=4ms TTL=64
Reply from 192.168.1.199: bytes=32 time=3ms TTL=64
Reply from 192.168.1.199: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.1.199:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 4ms, Average = 2ms
Then I get
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.199: bytes=32 time=6ms TTL=64
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Minimum = 6ms, Maximum = 6ms, Average = 6ms
    Win 8.1 Pro
    Toshiba
    core i7
    16 Gig
    Nvidia 770
    ie 11
    MS
2xg
Hi everyone!
96
Welcome to Eight Forums,
This could be a network card driver issue and depending on the chipsets of your computer. Some Users have encountered disconnection issue after upgrading from 8 to 8.1, possible solution is to try downloading the latest driver for your network card from the manufacturer's site. Also, please check out this Thread.
For Broadcom NIC drivers try downloading the Windows 7 driver, check out this Thread.
    Win 8.1 Enterprise
    Lenovo
    Intel i5
bz6djs
2
Hi Guys,
I figured this one out!! Turns out Windows 8 uses AppContainers now which by default, are forbidden from sending network traffic to the local computer (loopback). Once I used the enable loopback utility and added all of my apps to the exemption list all began to work properly. Thanks for all of your responses!
    Win 8.1 Pro
    Toshiba
    core i7
    16 Gig
    Nvidia 770
    ie 11
    MS
jimbo45
Hafnarfjörður IS
4,373
Hi there
glad it worked - however could you as a favour tell me what the "Loop back" container is --I don't seem to have any problems accessing an HP network wireless (wi-fi) printer from any of my systems (W2003 server / w2012 server, XP, W7, W8, W8.1
I'm not a networking guru - sometimes things just "work" although I've never heard of "app containers" before.
How do I enable "The loopback utility" in case I need this in the future.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
