Solved Win 8.1 desktop right click takes 15 seconds!
10
I upgraded from Win 8 Pro with Media Center to 8.1 Pro with Media Center. Upgrade went smooth (but what's with going completely thru the install BEFORE asking if you accept the new license?)
But now it takes 15 seconds to open the right click menu on the desktop as opposed to probably less than 1/10 of a second before. All other right clicks seem normal. No significant CPU usage during the wait.
If it matters, I'm pretty damn vanilla but I do have Start8 and ModernMix.
Also if its significant, Catalyst Control Panel won't start (I'll reinstall the latest but it was current less than a week ago).
Also my secondary monitor is set to the correct resolution (1920x1080) but its shrunk with a more than half inch black border around it. I'm hoping the Catalyst/driver reinstall fixes this too.
    Home built
    I5-2500K
    ASUS
    16GB
    Radion HD 6670
    ASUS 27", ASUS 24"
    1920x1200, 1920x1080
10
I just noticed it has the time wrong also. I'm still set to Arizona time (no DST) but it incorrectly shows time an hour later than actual and when I change to a different timezone it stays an hour off from what that time zone actually is.
I hope I didn't make a mistake by not waiting a week to upgrade.
    Home built
    I5-2500K
    ASUS
    16GB
    Radion HD 6670
    ASUS 27", ASUS 24"
XweAponX
Was it an upgrade over Windows 8, maybe you had something that wasn't working right in 8 before you updated it- Or maybe a program thats not quite compatible with 8?
Check your CPU and Hard Drive, see if they are pegged out to 100%, and check your Startup Programs, disable them all and then turn them back on one by one until the issue comes back.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
topgundcp
San Jose - California
2,847
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
10
As I said, there was no CPU usage other than the usual trace amount. Per your suggestion, I checked and there was no I/O either.
You might have a shell extension that was compatible with Windows 8 but not with Windows 8.1.
Please try this:
http://www.eightforums.com/performance-maintenance/19373-right-click-menu-lag-my-pc.html#post187343
That was it. An Nvidia extension.
Thanks!
FWIW I was not happy to find that even after using Nvidia's remove everything procedure, this extension remained AND worse still, there were still several hundreds of registry references to Nvidia stuff. Basically ticking time bombs and performance robbing clutter. Same with files in the Windows folder.
For readers, this was not a problem caused by the Win 8.1 upgrade. That extension was improperly handled by the upgrade from Windows 7 to Windows 8 last year. The extension was for an older version of drivers and has served no purpose since then. But it didn't go nuts before Win 8.1.
Anyone know if it would be suicide to delete all the remaining files in the Windows folder from the install that included the bad extension? I was able to identify them all by file create time stamps. I just don't know what bad things can happen with registry entries that might point to them. But none of those files are supposed to be in a Win 8 or 8.1 system, so damned if I do and damned if I don't?
    Home built
    I5-2500K
    ASUS
    16GB
    Radion HD 6670
    ASUS 27", ASUS 24"
XweAponX
In other words, it WAS a compatibility problem, glad it got nailed. Context Menu would have been my next guess, but he got it. I always do a fresh install of any drivers, even if a Windows 8.x update seems to update them.
I use nVidia so I'll probably see this happen when I Update to 8.1 - The "GeForce Experience" Program that handles updating the Drivers has a "Clean Install" selection.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
topgundcp
2,847
Glad you got the problem fixed.
You can remove the extension from the NVIDIA Control panel->Desktop and uncheck Add Desktop Context Menu
See screen shot:
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Hi friends, there is yet one more solution. The culprit is "Bluetooth".
Try this.....Hover your cursor to right top corner of the screen to bring out Charms. Click on "Settings" or the cog wheel icon click on "change pc settings" at the extreme bottom. Click on "PC and Devices" on top of the list then click on "Bluetooth" and switch it "On" (If its On, switch it Off) and leave it On or Off respectively, close the window. Check right click delay now.
Please post your comments : Whether it helped you or not so that it helps others like you too (y) cheers ;):D:cool:
    Windows 8 Home
    HP Pavillion
