Will they get away with Defender?
SIW2
Team Member
There is vast amount of money at stake.
Not sure how MS is going to try and get away with this one.
    7/8/ubuntu/Linux Deepin
Indeed, this should be interesting, SIW.
Still, MS is already giving away MSE (renamed Defender in Win 8) for free so I think the course of action that will eventually be taken will be to allow an uninstall of defender and an install of an AV of one's choice.
I'm glad MS is building Defender in on the pre-beta builds though.
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    Laptop 17", Gateway 20"
    1440x900 (x2)
I doubt. MS's burnt its fingers with WMP and IE bundled. So after N and E versions we might see D (without defender).
McAffee, Norton and the oem's in particular could be seriously out of pocket.
The oem's argue their take from selling pre installed trials ( largely the a/v S ) helps keep the unit price down.
If people realise they don't need to buy McAffe when it pops up after 30 days saying the trial is up - that is tens of millions of dollars.
I understand the oem's get most of it - don't know the precise figure , could be 75-80% , plus the same on renewals.
Do the math - Michael Dell alone sells 30 million machines a year.
If only 1 in 10 buy the a/v at $30 , then renew at $20 - you get the picture.
I have a suspicion it much more than 1 in 10 .
Hi, Aaron. :)
Can't say I've ever used MSE on my own machine (until now with Win 8 8102) but I have installed it on many other machines for others.
To me, the incarnation of Defender looks the same.
As far as disabling it, other than going into services, just as many here didn't realize it was even installed, I don't see an obvious way to fully disable it.
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
Doesn't matter if it can be done.
Fact is - it is included .
That is MS using it's dominance to erect barriers to competition.
I am not sure it is the competition authorities that will be the difficulty here - oem's and the a/v makers are more likely to scupper it.
I never used Vista, Aaron. I skipped over it and went to Win7.
Still, is that any more obvious than understanding Defender is now MSE in Win 8 8102?
One has to go to "Program Files\Defender\MSASCui.exe" to get to the interface. Otherwise, it's all automatic.
Really, what's the difference between MSE and the new incarnation of Defender in 8102?
I'm not attempting to start a fight here, just seeking clarification, Aaron.
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
How does one define a monopoly? Suppose MS decided to beef up its disk management console so it started doing all (or most) of the things now possible only with partition wizard/paragon and such like. Would that be monopolistic? It can be argued that creating/formatting/resizing/shrinking/extending/merging partitions is an inherent part of OS installation and maintenance.
I suspect it depends on who the affected 3rd parties are. Partition wizard/paragon chaps probably have neither the financial muscle nor the financial stakes to chase the issue. AV vendors are a different category.
Still, what's the difference with Defender, as it is in Win 8102 as compared to MSE in Win 7 and earlier?
I still have seen no real clarification.
As far as I can tell Defender in Win 8 8102 is nearly identical to MSE in Win 7.
Aaron brought up something about "network" something or other but that appears to be covered in other areas of Win 8 8102.
Again, I'm not attempting to start a fight, just seeking clarification on Aaron's previous posts related to this matter and his uncharacteristic Super Mod way of going about it.
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
Well, one way the new Defender is different from and would probably NOT be removable completely is that it is supposed to interface with secure boot on UEFI systems. Secure boot is MS's way of authenticating boot components which will apparently ensure that only signed and validated code makes it way upto the OS loading.
Thanks, Bill, still, MSE is built into Win8 8102 under the name of "Defender."
From what you presented, it seems even better than MSE in Win 7.
Again, I have yet to see anything that indicates, intrinsically, it's any different or lacking anything MSE in Win 7 offers.
Basically, MSE is built into Win 8 8102 with benefits, right?
The interface, to me, is practically identical.
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
When I finished installing Win 8, I automatically installed an AV (in this case MSSE). Are you guys saying that this is not necessary with the present build ?
    Win 8x64 - Win 7x64, Win7x32
    ME. Due for upgrade.
    Pentium D 925 Presler (old) Want i5 2500
    MSI G41TM-P33 El cheapo. Want AsRock Z68
    2GB DDR2 667 (Have pkt of 2x4GB DDR3 PC1600)
    GT240
    Realtek HD Audio chip
    Asus MW221u - Samsung Smart TV 40" LED
    Win 8x64 50GB (Partition)
    Win 7x32 500GB
    Win 7x64 320GB
    2 x 1TB Ext USB WD
    Corsair VX450
    Asus Vento
    Multi fan
    HP
    MS Wireless Mobile 1000
    16 Mb/s down, 128 KBs up. ADSL
    Laptops:
    Pavilion 1216AX dual core, 2GB DDR2 667
    Compaq CQ62 404ax, Triple core AMD, 8GB DDR3
    All systems plus PS3 used for Folding@Home Team 38444
I wouldn't be using Defender in a corporate environment, so the facility to uninstall - or not install - is a useful one. If it proves to be as robust and as up to date as the competition - i.e. with regards viral signature distribution - then I think it will be a great boon to the Windows world. For corporate use, I need central administration, monitoring and frequent updates.
    Win 7
    i7 860
You can use MSE in win8 instead of Defender (still now I don't know what Defender in win8 look like @@). May Defender will be switched with MSE.
I will try Norton Internet Security, hope it works :D
    DELL Vostro 1088
Defender in Win8 is practically identical to MSE.
You don't need MSE in Win8 8102.109 pre-beta.
How many times do I have to present this?
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
Yup. :D
    Toshiba
    Core 2 Duo T5500
    Intel
    4 GB
    Intel 965
    1440x900 (x2)
Thank you. It was an automatic action, LOL.
    GT240
    Win 7x32 500GB
    Win 7x64 320GB
    2 x 1TB Ext USB WD
    Corsair VX450
    Asus Vento
    Multi fan
    HP
    Laptops:
I don't view an antivirus the same as media player or a browser as its sole purpose is to maintain and protect the integrity and security of the Operating System , its not a third party application ?
I reckon including the AV in windows builds could well become a given and if the user wants to add their own security they can ?
Interestingly It would place the owness totally onto Microsoft which means they could potentially be held liable for any security breach if their inbuilt security failed to keep user information safe ?
    Win7 , win 8 on laptop
    self built
    Intel Core i7 3770K,1155, Ivy Bridge
    MSI Z77A-G43 Z77
    12GB TEAM ELITE (3x4GB) DDR3 1066MHZ PC8500 CL7
    KFA2 GeForce GTX 670 EX OC 2048MB GDDR5 PCI-E gfx card
    Onboard HD
    ASUS VK222H 22"
    1680 x 1050
    Kingston 128gb SSD
    OCZ Vertex 90gb
    500GB WDCaviar 16mb 5000KS
    320GB WDCaviar 16mb 3200AAKS sata 2
    1TB Samsung 16mb HD103SJ sata 2
    Corsair HX 750W ATX2.2 Modular
    Antec 25 Kuhler H2O 620
    logitech thing
    logitech MX518
    7mbps
I always used MSE in windows 7 with no problems. Windows Defender in w8, is identical to MSE as far as I can tell so I'll just carry on using it. I can't see the point in installing another anti virus.
    windows8 64bit
    self build
    Intel Core 2 Duo E8400 @ 3.00GHz
    Intel Corporation DQ45EK (LGA775)
    DDR2 Size 4096 MBytes
    M197WDP on Intel Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)
    Asus Xonar
    LG FLATRON M197WDP
    64gb ssd drive as my c drive
    488GB SAMSUNG SAMSUNG HM500JI ATA Device (SATA)
    244GB SAMSUNG SAMSUNG SP2504C ATA Device (SATA)
    OCZ 500W ModXStream Pro Power Supply - UK
    coolermaster
    60mb
