From the ipconfig you have a valid IP for the wireless connection. What are using Hamachi for?
You will want to set the connection up to use WPA-2 with AES encryption, it sounds like you are using WEP for some reason?
Best to go into the routers set up page to change the connection details then delete the old wireless profile and create a new one using the same credentials, encryption etc. as you have for the router.
First,
thanks for the quick reply! I realised I made a mistake: I was
using my WiFi dongle when I ran ipconfig. I'll put another one with the info from when I don't have my dongle in. I'm using Hamachi to connect to
private Minecraft servers as the person who hosts finds port-forwarding and manually setting local IPs difficult. I
would change the router security/encryption, but I don't want to mess up the
20+ connections to our router (though we never have them all on at the same time, of course). Also if I remember correctly Nintendo DS consoles
can't connect to WPA-2 networks? (I think the
Nintendo DSi and
3DS can but
only in the
browser and self-updater.) Thanks for the reply anyway. Also I'm not sure what you mean by "wireless profiles". Could you explain?
EDIT: Here's the ipconfig I promised you up there at the top of the post!
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : md-win8retail
Wireless LAN adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 00-26-C6-25-9B-E5
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Broadcom NetLink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 00-1F-16-C9-82-3A
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN
Physical Address. . . . . . . . . : 00-26-C6-25-9B-E4
Link-local IPv6 Address . . . . . : fe80::a8df:fb85:85a:e4c%12(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.14.76(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 251668166
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-42-C8-12-00-26-C6-25-9B-E4
DNS Servers . . . . . . . . . . . : 2001:4860:4860::8888
2001:4860:4860::8844
192.168.0.1
90.207.238.97
Ethernet adapter Hamachi:
Description . . . . . . . . . . . : Hamachi Network Interface
Physical Address. . . . . . . . . : 7A-79-19-72-B3-3C
IPv6 Address. . . . . . . . . . . : 2620:9b::1972:b33c(Preferred)
Link-local IPv6 Address . . . . . : fe80::5831:4814:ec5c:95f8%16(Preferred)
IPv4 Address. . . . . . . . . . . : 25.114.179.60(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Obtained. . . . . . . . . . : 04 October 2013 17:02:00
Lease Expires . . . . . . . . . . : 04 October 2014 17:02:00
Default Gateway . . . . . . . . . : 2620:9b::1900:1
DHCP Server . . . . . . . . . . . : 25.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 461011299
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{A977423C-7EFC-4F5C-AE49-7A1B86843E43}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{17FFF840-D3B3-4518-B0B3-4A64FF683805}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
