Wifi does not connect, limited connection or cannot connect
robotnik
hi, i have an alienware m15x r2 which i recently upgraded to windows 8 through a clean install. everything works great except for the wireless, and i cannot for the life of me figure out whats run. ive tried about 10 different wifi points on campus and tried wirelessly tethering tommy phone and nothing works. the wireless card is a broadcom aw1397. also when i run ipconfig, it says there is no default gateway for the connection
Did you install the driver for your wifi adapter?
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
ProtoType
Google Master
I have the same problem with an atheros adapter. I installed windows 8 on a toshiba, but it won't connect to wifi.
A separate USB Wifi adapter connects but the atheros doesn't... It's probably the drivers, although I haven't really stressed over it since I don't use it much...
Good luck, try to update the drivers in computer 'Manage'
    i5-3210M
    m6 1125dx
    8GB
    HD 4000
    Beats Audio
    750GB
    Hp
    Dry Ice and fridge
    Sticky
    Dead
    Almost hit 2kbps
    I'm trying to get win8 onto iPad as main OS
    Have an Hp Envy Laptop
brummyfan
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
chev65
Closed
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
