wifi connected; ethernet card will no longer connect
fotyc
40
Windows 8.0 user with my recommended Windows updates up to date (except as removed by system restore mentioned below); Samsung NP550P5C laptop; Realtek PCIe GBE Family Controller. A couple of weeks ago I noticed that I no longer had a wired connection on my laptop, only the wifi. For ages I've run with both connected, it prioritized the wire, and I never had a problem, but the wired connection dropped out and will not come back to life even if I disconnect from the wifi. I spent a lot of time over the past few days doing online research, didn't want to get too aggressive but here is what I have tried:
Give the ethernet card's MAC address a static IP on the gateway (Actiontec router provided by Verizon)
Attempt to configure the IPv4 properties on the ethernet card to use the right default gateway and mask (these have gone south as you'll see in my ipconfig dump below)
ipconfig release and renew - renew never completed
New cable (that was my first try)
New driver
Fell back to old driver
System Restore back to the beginning of the month
The router is also new, Verizon sent me a new one which I installed at the beginning of this week. No improvement. I have to admit that I didn't dig deep into these settings while using the old router because it was also dropping wifi a couple of times a day and so I thought it was just failing.
At first it would not recognize the cable but then I read somewhere to adjust the speed and duplex from Auto detect to just anything else in the list to see if one worked, and when I chose 10gbps and full duplex, the adapter woke up and I could see the light on the router come on for the connected port. However, it doesn't recognize the network (how disloyal, it's been using it for years...) I can now also see the computer listed on the router's page of network connections. However, the computer thinks this is an unknown public network with no connectivity.
Here is my ipconfig dump. I made some notes in red... and the bolded items strike me as WRONG.
Windows IP Configuration
Host Name . . . . . . . . . . . . : CarolineSamsung
DNS Suffix Search List. . . . . . : domain.actdsltmp
Wireless LAN adapter Local Area Connection* 12: do not know what this is!
Physical Address. . . . . . . . . : C4-85-08-E0-C0-E6
Ethernet adapter Bluetooth Network Connection: I have a bluetooth device I sometimes use, maybe this is that
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : C4-85-08-E0-C0-E9
Ethernet adapter Ethernet: HERE IS MY PROBLEM CHILD!
Connection-specific DNS Suffix . : should be something here, yes?
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 50-B7-C3-81-2C-AA
Link-local IPv6 Address . . . . . : fe80::b4f8:1285:9368:a9e1%13(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.169.225(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 357611459
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-53-A9-C2-C4-85-08-E0-C0-E5
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Wireless LAN adapter Wi-Fi: working; rock solid so far
Connection-specific DNS Suffix . : domain.actdsltmp
Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6235
Physical Address. . . . . . . . . : C4-85-08-E0-C0-E5
Link-local IPv6 Address . . . . . : fe80::164:cc8c:f716:e84c%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Lease Obtained. . . . . . . . . . : Thursday, June 25, 2015 7:12:27 PM
Lease Expires . . . . . . . . . . : Thursday, July 2, 2015 7:12:26 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 264537352
DNS Servers . . . . . . . . . . . : 192.168.1.1
Tunnel adapter isatap.{C9981BEA-B48B-4112-AF39-4D2589B1C3FE}: don't know what these tunnel things are...
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.domain.actdsltmp:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
I also did a couple of netsh commands I found online but they seem to have accomplished nothing.
I thought maybe the ethernet card had died, but if I now have the light on and it visible in the router the card isn't dead. I tried using a command prompt to ping 127.0.0.1 and it worked fine although I'm not sure what that proved...
I saw lots of people with this problem all over the internet but nobody's solution has worked for me so far, so I'm coming to the smartest Win 8 people I know... Screenshot of network map below (wifi clients are I think my daughter's phone, her iPad, my laptop, and the network printer. Have I provided enough information? Thanks for any pointers. Maybe it's time to buy a USB ethernet dongle?
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    SAMSUNG ELECTRONICS CO., LTD. NP550P5C-A02UB
    4gb
    Intel
    "High definition audio device"
    Generic PnP Monitor (15.3"vis)
    1366x768
    Hitachi HTS547575A9E384 750gb SATA
    "HID keyboard device"
    "HID compliant mouse" and Amazon wireless mouse
    it's Verizon DSL so 2.5mbps :-(
    Avast
    Online Armor
    Emsisoft Antimalware
    I have Belarc Advisor which can pull info better than the device manager if any is needed.
broe23
Retired from the grind
Central IL
3,468
Most likely you screwed something up either on the IP for the Ethernet card on your computer, or did it on your Gateway. Check out ezlan.net for further info how to do what you want to do.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
popeye
United States
3,090
Does the Ethernet work when wireless is off? Have you reset the router?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
fotyc
40
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
fotyc
40
I fear that I did; but I don't know exactly how... Gateway is new out of Verizon's box pretty much.
I went to that site but can't exactly figure out how to find anything there; will spend some time poking about tomorrow, thanks I hadn't heard of it.
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
Ztruker
Open Device Manager.
Expand Network Adapters.
Right click on Realtek PCIe GBE Family Controller and select Uninstall (don't uninstall driver is offered)>
Reboot.
Windows will detect and reload the drivers for the NIC. See if that helps.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
fotyc
40
Reboot.
That is another thing I already did, sorry I forgot to list it.
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
Ztruker
Any way you can connect via Ethernet at some other location?
COuld also try one or more drivers from here if you have not already: Realtek - Software: Drivers & Utilities
I have the same NIC and am using this driver:
which I believe I got via Windows Update.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
broe23
Central IL
3,468
#9
fotyc it is the best website for helping through Networking stuff. The only Items in my house with Static IP's, are my NAS, my two Access Points, my Ted 5000 and my IP Security Cameras. Everything else is Dynamic IP handed out by my router that is connected through DMZ+ mode to my ATT U-Verse Gateway.
The way I did my statics. I let the Router assign them, then went into the device and unchecked to allow it to get a Dynamic IP from the Router, then put back in the IP, if those fields were erased, when swapping from Dynamic to Static.
Most routers these days will use what is called a "Sticky Dynamic IP". That means that it never changes, unless you do a IP Clear, or Factory reset on the router.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
broe23
Central IL
3,468
#10
Scratch that on that link I gave you. It appears that he has taken a lot of the info offline. It used to be a really good guide. but not anymore.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
fotyc
40
#11
Hm, that would be falling back even further than the one I have, but it's worth a try. The Realtek site is now offering
Win8, Win8.1 and Server 2012 Auto Installation Program (SID:1726143)​
[TD="class: etxt-top10-box, bgcolor: #FFFFFF"]
[/TD]
[TD="class: etxt-center, bgcolor: #FFFFFF"]8.038[/TD]
[TD="class: etxt-center, bgcolor: #FFFFFF"]2015/5/27
[/TD]
I am wondering if setting the ethernet card properties to 10mps full duplex is somehow wrong - it's the only speed/duplex setting that allowed the card to recognize it has a cable plugged in, but is it a problem not to use Auto Detect?
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
fotyc
40
#12
This thread was the one I was using, but ultimately the way the guy fixed his problem didn't seem to apply to me or my Windows version.
I did not do this: Should I try it?
"Unplug the power plug to the Modem and the Router. Plug the power into just the Modem (unless you have a modem/router combo) When all the lights come up, plug in the power to the Router (unless combo of course)
Now Go to Start/Search and type inetcpl.cpl and press enter/Connections/LAN Settings. Make sure all the boxes are unchecked. Now go to Start/Search and type ncpa.cpl and press enter. Right click the Local Area connection/Properties scroll down to Internet Protocol (TCP-IP)/Properties. Make sure Obtain an IP Address and DNS Server Address Automatically are both checked. Now go to Start/Search and type CMD Right click the CMD icon and Run As Administrator. In the Command Prompt type ipconfig /release and press enter. the IP Address changes to 0.0.0.0 Now type ipconfig /flushdns and press enter. Now type ipconfig /renew. Now type ipconfig /all. You should have a new IP address try it again."
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
Ztruker
I have not messed with any of the settings for my NIC. If auto is default that's what mine is set to.
Have you tried booting to Safe Mode with Networking. It's a bit hokey to do in Windows 8:
Windows key + C.
Settings
Power
Hold shift key and click RESTART.
Click on Advanced Options then Startup Settings.
Click Restart and you have almost the full advanced Boot Options menu like XP, Vista or Win 7..
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
fotyc
40
#14
Have not booted in Safe Mode yet. I can try that this weekend. I just updated my post above to add a suggestion from that other forum that I did not try, I wonder if I should.
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
DMHolt57
Austin, Texas
1,585
#15
I would try to go into Network and Sharing, on the left select Change Adapter Settings. Right click on the Ethernet adapter and select properties. Uncheck Ipv6, right click on Ipv4 and select properties, click on the advanced tab and enter 192.168.1.1 in the gateway. Reboot with the cable plugged. That should put the adapter back to the correct subnet mask of 255.255.255.0 You could also try giving the adapter a static address of 192.168.1.20 and subnet set to 255.255.255.0 and gateway again is 192.168.1.1
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
fotyc
40
#16
I did some of these things and it didn't work; I will try again.
I should add: I use Online Armor free firewall and Avast free antivirus, and I run a malware scan a couple of times a week with Emsisoft Antimalware....Malwarebytes also told me I was clean when I ran it yesterday. So I don't think I'm looking at an infection.
I appreciate everyone's suggestions, bring 'em on!
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
Ztruker
See how it works in Safe Mode with Networking. Maybe the firewall or AV is causing the problem.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
fotyc
40
#18
Safe Mode with Networking: Same exact status with respect to the ethernet card.
I was going to try the suggestion from post #15 but if I choose the check box that opens up the default gateway box for entry, it requires me to specify my DNS servers, and I don't know what to put there. I tried also putting 192.168.1.1 in the primary DNS box but that didn't work. Is there something else I'm supposed to put in the DNS boxes? Thanks!!!
As an addition to this: in an attempt to answer my own question, I looked at the properties on my Actiontec router and have the values below. Should I be using these values for anything?
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
popeye
United States
3,090
#19
8.8.8.8 and 8.8.4.4 those are the Google public DNS servers.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
fotyc
40
#20
OK tried all of this; ipconfig for my two devices now looks like this, but still I have an unidentified network. Wireless adapter continues to work great. It says DHCP enabled: NO which looks WRONG to me... Oh, I see, because I chose an IPv4 address. Well. See anything else that looks wrong? Still says 'unidentified network' for the adapter.
IPv4 Address. . . . . . . . . . . : 192.168.1.20(Preferred)
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
Lease Obtained. . . . . . . . . . : Friday, June 26, 2015 4:48:00 PM
Lease Expires . . . . . . . . . . : Friday, July 3, 2015 4:48:03 PM
    Windows 8 x64
    Samsung NP550P5C
    4ghz Intel
    4gb
    Intel
    1366x768
    Avast
    Online Armor
