wifi/bluetooth device not detected after reboot
nabilalk
42
Since upgrading my HP DV6T7000-CTO from Windows 7 to Win 8 and now 8.1I have had an intermittent issue where the my wifi/bluetooth adapter is detected, until a restart, and then afterwards, is no longer detected. I have a Intel centrino wireless N 2230 which is both wifi and bluetooth. I cannot connect to wifi, nor is the bluetooth detected. Additionally, the wifi-radio button on my laptop, will not turn on (red is off, white is on). Sometimes I can temporarily fix the issue by shutting down, disconnecting the adapter from my laptop, reseating it, and then rebooting. This does not always work though.
I have tried the latest drivers from Intel as well as tried removing those and just installing whatever Windows update thinks is best. I have also updated the Bios to the latest, but to no avail. I have even replaced the adapter with a new adapter but the same model and that did not fix the issue either. For that reason, I am thinking it could be a driver issue. But, I have never experienced a driver problem where something would go from working properly to not being detected at all after a reboot. Any help figuring this out would be of great help.
    Windows 8.1 Professional amd64
    HP DV6T7000cto
popeye
United States
3,090
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
nabilalk
42
    HP DV6T7000cto
