Wi fi issues
Fixer58
Whittier , calif.
I have a sony vaio laptop operating system is windows 8 , my problem is it connects to wi fi but not to the internet , play store, etc every time I try I get a pop up saying I have no wi fi connection. Any ideas , any input that points me towards solving this problem I thankyou very much , your help is greatly appreciated. . Fixer58
Does a normal network icon appear in the task bar, i.e, without X or yellow triangle?
If a normal network icon apears, the number of devices connected to internet may has exceeded the maximum allowed number set by your ISP.
Have you attempted to reboot your router? (Pull the power plug from the outlet, wait 30 seconds, plug back in.) Rebooting the router can often fix weird problems like this.
Has this laptop been able to connect in the past?
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet)
    Home built i7-8700K, Hp Envy x360 EVO Laptop, MS Surface Pro 7
    3.7Ghz Core i7-8700K, 11th Gen Core i7-1165G7 4.7Ghz, 10th Gen Core™ i5-1035G4 1.1Ghz
    ASUS TUF Z370-Pro Gaming, HP, MS
    16G, 8G, 8G
    AMD Radeon RX580, Intel Iris X Graphics, Intel Iris Plus Graphics G4
    ATI High Definition Audio (Built-in to mobo)
    Dual Samsung U32J59 32 inch monitors, 13.3" display, 12.3" display
    3840x2160 (Desktop), 1920x1080 (laptop), 2736x1824 Pro 7
    500GB ssd boot drive with 2 & 10TB Data (Desktop), 512GB ssd (laptop), 128GB SSD (tablet)
    Corsair CX 750M
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    665Mbps/15Mbps down/up
    FireFox, MS Edge
    Defender on all
    Retired in 2015 after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant. Retired for 3rd (and final) time in 2019.
