Why is Searchindexer running
daniellouwrens
Hi
My W8.1 PC is fully updated.
I do not have any Hard Drives or Partitions set to be searched in the Drive Properties dialogue box, so
why is Searchindexer running all the time and using RAM?
Cheers
Daniel
    Windows 8.1 x64 with 8.1 Update
    Asus
    Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
    Asus
    8Gig
    Poor
    Asus
you can go to admin tools /Services ,in control panel and turn it off
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Hi
Thanks, will that disable anything else, IE are there other dependencies?
Cheers
Daniel
    Asus
    Asus
    8Gig
    Poor
    Asus
Hi
Cheers
Daniel
that's likely a good question ,myself I have disk indexing disabled ,
maybe if you set the search indexing service to manual first, to see if that stops it from acting up on you ,at least that will have it set so if you do go and use search indexing it will turn on for you
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
