What cable should I use from my gpu to monitor?
Crazykilla
Behind you.
46
Hello, I'm CrazyKilla
Currently I'm using a dvi to vga converter on my gpu to a vga cable into my monitor.
I hear the best cables to use are hdmi and displayport, but last I tried hdmi it only allowed me to go up to 1920x1080 (my monitor is 1920x1200).
My monitor does not have a displayport input, could I use a display port to vga/hdmi and still get all the goodies of displayport, or will there be a downside?
Would it even make a difference to use a display port rather than dvi to vga?
    Windows 8 Pro
    Intel Core i7 3820 Quad Core 3.60GHz
    msi X79A-GD45 8D
    16GB 1666Mhz Corsair Vengeance
    EVGA GeForce GTX 780ti
    None
    HP w2408h
    1920x1200
    2TB Western Digital Energy saving 6gb/s
    Corsair GS800 Gaming Power Supply
    Zalman Z9 Plus
    6 120mm Fans + Intel All in one Cpu liquid cooler
    ROCCAT Illuminated Gaming Keyboard
    Sharkoon Fireglider Laser Mouse
    Virgin speed.
    Chrome.
    None, anti-virus for pussies.
    I like sex.
Dude
Active Member
403
    W10 Pro X64
    Dude
    Intel(R) Core(TM) i5-3570K CPU [email protected] 4.5 GHZ Turbo
    MSI Z77MA-G45 (MS-7759)
    8.00 GB DDR3 1600Mhz
    PNY GTX 760
    Realtek High Definition
    Dell S23O9W, HP L1710
    DELL-1920 x 1080 HP-1280 x1024
    Crucial m4 256 SSD WD 7200RPM 500GB
    Seasonic X650 Gold
    Zalman Z12
    Antec Kuhler 920
    Logitech
    MSI DS100 Interceptor
    50 down 5 up
    Chrome, IE 11
    Logitech X-620 Speakers
alphanumeric
slightly off center
Gold Member
If you can get 1920x1200 out of the VGA connector you should also be able to get 1920x1200 out of the DVI on the same video card. If its the same DVI connector that the DVI to VGA adapter is on its already running at 1920x1200. They can't run at independent resolutions on the same connector, they are feed from the same VPU.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
