Solved Watermark Removal Anyone???
Ex_Brit
Older - But No Wiser
Anyone any clues about doing that? I used one fix I found online but that only removed the build number and not the huge Microsoft Confidential blurb.
Edit: This thread was about the Developer Preview but has been solved for the Consumer Preview, see post #28.
    Win 7 Ult SP1 + Win 10 Pro - (x64)
    Alienware® ALX X58
    Intel® Core i7-975 Extreme 3.86 GHz 8MB Cache
    ASUS P6T Deluxe V2 Socket 1366 Core i7, Dual Triple Channel DDR3 Mem
    24GB Corsair Vengeance DDR3 SDRAM at 1600MHz - 6 x 4096MB
    1792 MB NVIDIA® GeForce® GTX 295/Hauppauge HVR2250 TV Tuner
    Onboard Soundmax® High definition Sound
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    1 X 3TB external eSATA
    (Non-RAID)
    Alienware® 1200 Watt Multi-GPU
    Alienware® P2 ALX Chassis with AlienIce 3.0 Video Cooling
    Alienware® High-Perf. Liquid Cooling + Acoustic Dampening
    Microsoft® Wireless Entertainment 8000 + Logitech® G15 Wired
    Microsoft® Wireless Laser 8000 + Logitech® G9 Wired
    1tbs
    Using non-RAID on purpose as I find it too fussy and temperamental.
Airbot
Super Moderators
You don't get the "huge Microsoft Confidential blurb" in the Dev Preview version, unless you've disabled the immersive/Metro UI with one of the hacks to do so.
    LCARS
    Monkey Trainer Extraordinaire
    My toilet habits are a private matter, thanks.
    She finds stuff to do.
    Not that I can recall.
    XXX rated
    Huh?
    Monitors are lizards.
    I haven't found one yet.
    Sure isn't easy driving.
    Again, toilet habits are a private matter.
    Pending
    2 ice cubes.
    Nar, it has other key friends.
    Cat
    Warp 9.9
Ex_Brit
Ah....well maybe I'll try reinstating the Metro thingies and try to cope with occasionally getting stuck on certain screens with no clear way out.
Thanks
    Alienware® ALX X58
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    (Non-RAID)
    1tbs
Airbot
Super Moderators
    LCARS
    XXX rated
    Huh?
    Pending
    2 ice cubes.
    Cat
    Warp 9.9
Ex_Brit
I just spotted that and thanks for posting it. I seem to still have a remnant on the regular desktop.
    Alienware® ALX X58
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    (Non-RAID)
    1tbs
davehc
I have Applied no hacks, but I've got the Microsoft Confidential notice.
    Use several different computers during a day, so specs are irrelevant.
Airbot
Super Moderators
Must be something else then. I only get it if I apply a Metro disable hack.
Build 8102 x86 installed on a physical machine.
    LCARS
    XXX rated
    Huh?
    Pending
    2 ice cubes.
    Cat
    Warp 9.9
davehc
Mine was the 64Bit. Maybe??
Airbot
Super Moderators
What's with the background blue color there, is that a custom background, or..?
    LCARS
    XXX rated
    Huh?
    Pending
    2 ice cubes.
    Cat
    Warp 9.9
Bill2
Why do people want to remove that watermark? its a buggy build of an old OS pretending to be new, sooner it expires the better.
davehc
That was the one I selected (Solid Colours)
debugged
Here's the manual way to get rid of most of the watermarks:
Windows\System32\en-US\shell32.dll.mui
Take ownership and control
Open in Resource Hacker
String table Resource 2070
Delete lines 33108, 33109, 33118
Compile
Save
Reboot
Run > mcbuilder
Reboot
Has anyone found how to get rid of the last bit? Mine leaves ".b32615d501a711d0" but it seems to be different for every system.
    Windows 7
hoadqtk4
Compile
Save
Reboot
Run > mcbuilder
Reboot
Hi all,
In windows 8, if you remove its watermarks, you won't see "move file, folder process"
You can check it to see that "invisible copy box for your windows" and you can't stop, x with you copying process
thanks
    windows 8 Developer Preview
debugged
thanks
I don't have any problems with copy or move, or any other problems that came after removing the watermark. My only "problem" is how to get rid of the last little bit of the watermark.
    Windows 7
Ex_Brit
Hmm, all the removal tute's I've seen state that those last few bits will still appear. Very strange.
    Alienware® ALX X58
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    (Non-RAID)
    1tbs
jbecerril
Hi I'm a long time Ubuntu user and win8 sparked my interest so I switched... anyway, I cant seem to take ownership of the file is there a program or command line I can use I tried going through the properties with no luck. Any help would be appreciated.
also is resource hacker a program?
    WIN8
debugged
Hi jbecerril,
If you can't take ownership, usually it's because you're not running an Administrator account.
In Windows Developer Preview, right click on a file > Properties > Security tab > Advanced button: Click on the blue "Change" button. Then type "Administrators", or your user name. Then click on the Check Names button (it will change to add computer name) Click OK. Click OK again. Now click on the Edit button. Highlight "Administrators" or "Users" in the list. Tick the "Full Control" box in the bottom pane. OK.
Resource Hacker is a free little program for editing system files.
    Windows 7
epoc
Hi jbecerril,
Xda method in my post above has downloadable reg hack to take ownership with one click from context menu...bombproof
    wdp
    dv9000
    amd dual core
    2gb
    integrated
Gary
Banned
It would be nice to share that info.
    Windows 7 64 Bit
    Cyberpower
    i7 960 @ 3.20 Ghz
    MSI MS7522
    16 GB DDR 3 Corsair
    GeFoce 460
