VMware Player- wireless and USB
SteveCh
17
I have XP pro running as a guest on a Windows 8 PC. I now want to get onto the internet wirelessly to download some applications and also get the USB working to download work files onto XP. How do I do these two tasks?
    XP
    Dell
    Pentium
    AVG
SteveCh
17
I have read that VMware may have problems with USB3 ports. Unfortunately all my ports are USB3. Is this terminal?
    XP
    Dell
    Pentium
    AVG
Hopachi
Polyhedric Stellation
Orbiting the Moon
2,975
For the network, a default NAT config is more than enough:
for the USB, just add a USB controller, all will work, you can even use USB 2.0 virtually, host ports are backwards compatible.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
SteveCh
17
USB device is recognised by VMware when plugged in and shows on the staus bar. Shows it is active in the settings section. But it does not appear in My Computer on the guest OS.
    XP
    Dell
    Pentium
    AVG
Hopachi
Orbiting the Moon
2,975
It has to be installed in the guest OS as well, something which happens automatically. If this is XP, it might not be recognized but that not really expected.
Look in the Device Manager of the guest and look for USB or unknown or not working devices.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
