Solved VLC Taking 5 minutes to load
Jimfof1913
Washington DC
35
The VLC media player is taking about 5 minutes to load and run. No other program is having this problem. It was running OK then suddenly it started taking 5 minutes to load.
    windows 8 Pro
    Gateway
    Intel Pentium 2.70Ghz
    unk
    4GB
    unk
    1930x1080
    Wireless
    Wireless
    25Mbs
jimbo45
Hafnarfjörður IS
4,373
Hi there
are you using the latest version -- some older versions have some issues with "Fonts(?)"
There's a 64 bit version now available try that.
Normally VLC is just fine.
cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Jimfof1913
Washington DC
35
Rebooted my machine and now everything is back to normal. No idea what the problem was.
    windows 8 Pro
    Gateway
    unk
    4GB
    unk
    1930x1080
    Wireless
    Wireless
    25Mbs
