Videos and audio stuttering with mouse
morinr
Hello,
When I watch youtube videos, or videos in Windows Media Player Classic my audio randomly stutters. This also causes my mouse to stutter and skip and move slowly.
I have tried to fix this issue for awhile. However still no solution.
Any ideas or tips would be great, Thanks
    Self Built
    i5 3570k
    Asus P8Z77-V PRO
    8 gigs Gskill
    GTX 670
    1 TB Seagate Barracuda
    256 g Kingston Hyper X
    Azza Solano 1000
    Noctua NH-C14
    27mbs
    Chrome
    Avast
fireberd
Beach Observer
Can you fill in the "My System Specs". Without that we can't even offer a guess.
    Name
    Jack Stoner
    Occupation
    Retired
    Country Flag
    USA
    State/Region Flag
    us florida
morinr
Thanks, Just filled it in. It is just a pain in my arse. Its not unusable but randomly stutters and lags.
    Self Built
    i5 3570k
    Asus P8Z77-V PRO
    8 gigs Gskill
    GTX 670
    Azza Solano 1000
    Noctua NH-C14
    27mbs
    Chrome
    Avast
fireberd
Beach Observer
Well, with the system you have that should not be happening. I just built a second system using an ASUS P8 Z77-V LE Plus motherboard, an i5 3550 and 8 GB of GSkill Ripsaw memory (and . I'm, initially, using the built in Intel HD Video not a separate video card.
The first thing, do you have the correct sound driver installed? The driver from ASUS is the preferred. Second is the Intel motherboard chipset drivers. They can be downloaded from ASUS or Intel.
Other than those two drivers, there shouldn't be any IRQ interrupt problems. Does this happen with on-line video/audio only? or does it also happen with video or audio that you already have on the PC hard drive or if you play a commercial audio CD? Just trying to isolate it to where/what.
    Name
    Jack Stoner
    Occupation
    Retired
    Country Flag
    USA
    State/Region Flag
    us florida
Also make sure all your flash players are up to date. What type of mouse do you have and does it require a separate driver/firmware/software install?
    Name
    Jimbo
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
    Country Flag
    USA
    State/Region Flag
    us north carolina
morinr
I have the updated Sound drivers and chipset drivers from ASUS. I have the installed drivers for my mouse. The flash player I have installed is current.
The videos that cause the stutter are online as well as with windows media player classic.
Hope this helps you help me :)
Thanks
    Self Built
    i5 3570k
    Asus P8Z77-V PRO
    8 gigs Gskill
    GTX 670
    Azza Solano 1000
    Noctua NH-C14
    27mbs
    Chrome
    Avast
fireberd
Beach Observer
Is it ONLY videos that cause this? I'm still a bit confused, I see you mention on-line videos. Does this also mean videos that you have on the PC's hard drive (where did they come from?) also do this. Does a commercial Video DVD also cause this? Does just playing audio cause this?
If its ONLY videos that cause this, for testing, remove the GTX670 video card and use the built in CPU video and see if that also causes the problem.
    Name
    Jack Stoner
    Occupation
    Retired
    Country Flag
    USA
    State/Region Flag
    us florida
morinr
I have videos downloaded on hdd and they stutter when played. Then youtube videos and other streams cause the lag as well. I had the issue with a commercial dvd in the drive. But the issue was much less with he dvd. Only happened twice in a few tv episodes.
For uninstalling and trying withouht graphics card... Can I just unplug the power? Or do I physically need to remove the card?
I had my task manager open and when the stuter happens the CPU load from System goes up much higher. Generally it is at less than .5%. But with the stutter it goes up to just below 10%. No idea what this means or how to fix this but you might know.
When I am installing the chipset drivers. It does it nearly instantly... However the driver is 247mb when ziped. Is this an error? I checked with my device manager and states the driver is only at 6.2.9200.16451, which is from 2009. However I cannot install the new one now mater what I try. But then when I go to the intel driver scanner tool it says that it is updated and correct.
    Self Built
    i5 3570k
    Asus P8Z77-V PRO
    8 gigs Gskill
    GTX 670
    Azza Solano 1000
    Noctua NH-C14
    27mbs
    Chrome
    Avast
fireberd
Beach Observer
I don't think just unplugging the PCIe power plug will work, but you can try that. If not, then you will have to physcially remove the video card, to test the CPU video.
    Name
    Jack Stoner
    Occupation
    Retired
    Country Flag
    USA
    State/Region Flag
    us florida
