VIA Vinyl VT1708s + 3.5mm Speakers Strange Sound (only HDMI works)
fma965
6
firstly this is my first post so sorry if i sound noob.
ok so i installed windows 8 consumer preview build 8250 x64 last night. everything seems to be working correctly other than my sound. i am using VT1708s by via embedded in a asus m5a78l-m/USB3 motherboard now the problem is the sound is working fine via my HDMI connection but via the 3.5 mm jack the sound is all strange and un-usable its like according to my friend it sounded like it thought it was digital when it is analogue.
i have tried installed the windows 7 x64 driver from both asus and VIA but it didnt work still the same problem. i had to run it in compatibility mode.
please help me fix this thanks :D
    Win 8 CP and 7 x64
    AMD FX-6 6100 Black Edition 6 Core 3.3Ghz Socket AM3+
    Asus M5A78L-M/USB3 AMD Socket AM3+ 8 Channel HD Audio mATX
    Corsair 4GB DDR3 1600mhz Vengeance Memory Module CL9 1.5V Non-ECC Unbuffered
    Saphire HD6770
    Onboard (VIA Vinyl VT1708s)
    Acer AL 1717 LCD Monitor, LG 32lh3200
    1280 * 1024 , 1360 * 768
    WD 2TB 3.5" SATA-III 6GB/s Caviar Green Hard Drive
    CIT 750W Dual 12V Rail 12cm Fan PSU - 4x SATA 1x PCI-E
    Standard Old Case
    Stock + 2 Case Fans
    Standard DELL
    logitech wireless laptop mouse
    8-16mbp/s Download | 1-2mbp/s Upload
USA
118
I'm in the same boat with my board....only difference is my sound works with the windows built in driver but I can't get the VIA driver to load at all.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
fma965
6
well it doesn't matter what driver i use i get sound via HDMI but not working correctly via speakers. although on the actual windows driver their is no speakers output at all.
    Win 8 CP and 7 x64
    Saphire HD6770
    Standard Old Case
    Stock + 2 Case Fans
    Standard DELL
USA
118
The pains of a pre-pre release I reckon.
    Custom build
    Realtek HD onboard
    1600 X 900
    Logitech G510
Johner
2
How would I at least get the Windows built in driver to work then? I'm having this problem as well, but a temporary solution is better than no solution at all.
    Windows 8 Consumer Preview
    AMD Phenom II x4 955 3.2 Ghz AM3
    ASUS M4A87TD EVO | AMD 870
    4 GB G. Skill DDR3 1600 (PC3 12800)
    1 GB nVidia GeForce 9800 GT
    VIA Vinyl High Definition VT1708
    COOLER MASTER eXtreme Power Plus 500W
    GIGABYTE gz-ph2a3 Mid Tower
fma965
6
i can easily still use my speakers via windows 8 any way it just a bit of a workaround for now. plug speakers in to tv audio out then use hdmi :).
    Win 8 CP and 7 x64
    Saphire HD6770
    Standard Old Case
    Stock + 2 Case Fans
    Standard DELL
RolandHazoto
34
Anyone give this a go?
answers.microsoft.com/en-us/windows/forum/windows_8-hardware/no-working-sound-drivers-via-vt1818/e23f3927-e92e-46d7-8477-9bfc4618fbeb
A more detailed set of directions may be in order but perhaps someone can work it out?
    win 7 & 8
fma965
6
#8
from what i read they are saying install it in compatibility mode aren't they? that didn't work.
    Win 8 CP and 7 x64
    Saphire HD6770
    Standard Old Case
    Stock + 2 Case Fans
    Standard DELL
Johner
2
#10
Compatibility mode and hand change the driver. Worked for Johner.
Yes. I installed it in compatibility mode, then opened up Device Manager and uninstalled it. For some reason, that made the default Microsoft HD Audio drivers read my 3.5mm speakers.
Glorious Analog Sound. lol
revocomputers
53
#11
I have tried this, but the speakers just go again when I roll back the driver.
The strange thing is, I've been using Win8 for months without a problem, but I had to re-install it and now there's this problem :(.
Has anyone found a fix?
    REVO PC
    AMD Phenom II x6 1100T 3300MHz
    ASUS
    8GB DDR3
    Geforce GTX460
