uTorrent for Metro UI
cicmildjordje
Does anyone know how to use utorrent metro app. It asks me to add server, to type some IP adress and port. Can anyone post some example for working server. Thanks
topgundcp
Just curious, Why would you want to use this app ? I looked in the store, it costs $2.99 for it. What wrong with the desktop version ? What advantage do you gain for using this app ?
To answer your question: The server IP is the IP address of your PC, open command prompt and type ipconfig. The port number is a number to use for port forwarding and you can pick any number between 1~65534 and you have to login into your router to enter this information to match what you have set in the app. In addition, you need to set your PC IP address to be static.
For example: every time I turn on my PC, an IP address is assigned to: 192.168.1.2 and that what I assign in the router LAN section.
In the port forwarding section of the router, I set it to be: 45682 and you might ask why I use that number, the answer is when I install utorrent, it randomly assign that number and creates inbound & outbound rules for it in Windows Firewall so I just use it.
Hope this helps.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
