Using Win 8 on Virtual Machine and says no 64-Bit support
snadge
Hi
Iam using Windows Virtual PC which was a 64-Bit version I installed, I got XP Home 32-Bit installed via it perfectly and tried to install Windows 8 x64 AND THEN Windows 8.1 x64 but on both I got the BSOD (in the Virtual Machine) almost straight away saying 64-bit CPU is not supported?
ive read this may be due to not having VTx but I do as my CPU is a 3470 (Ivy Bridge) and SIW says its enabled as does BIOS
Iam testing some Windows ISO's to check to make sure they are OEM and ask for product key during install but also to diagnose a WSUS Offline issue in windows 8 that reverses all updates right at the end saying there was a problem, the software creator needs a log and I aint got time at work.
can anyone help with this or advise of better virtual machine software (noob)
thanks
    Windows 8.1 Pro x64
    Intel 3470 @ 3.67Ghz
    Gigabyte H77
    8Gb Crucial Ballistix Sport @ 1616Mhz 8-8-8
    Gigabyte GTX650 @ 1.1Ghz
    Via HD 7.1 108db SNR
    LG Flatron 19"
    1440x900
    1 x 250Gb Samsung EVO 850 (520,500,90,000,0.44ms)
    500Gb Seagate HDD
    XFX 450 Pro Core Edition
    Arctic Freezer Pro
    wifi combo Q-Connect
    16Mbps
    Chrome
    Private Firewall + WinPatrol
adamf
Banned
What is your host operating system? Your specs say Windows 8 - is that true? Are you really running Virtual PC on Windows 8? Is it 8 or 8 pro - 32 or 64 bit?
Assuming you are running windows 8 you can only run one type of virtualisation software at the same time.
Generally VMWare Player is the easiest (I think) and it is free from here https://my.vmware.com/web/vmware/free#desktop_end_user_computing/vmware_player/6_0
Disable Hyper-V first if you have it enabled or it will not work.
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
snadge
no i have windows 7 pro 64 bit - not changed specs in a while
thanks
    Windows 8.1 Pro x64
    Gigabyte H77
    LG Flatron 19"
    1440x900
    500Gb Seagate HDD
    Arctic Freezer Pro
    16Mbps
    Chrome
adamf
Banned
You may want to update the specs on your profile then - it just says OS Windows 8.
Did you try using VMware player or virtualbox? If your CPU supports VTx and it is turned on in the bios in my experience you only get this message if something else has assigned the feature (usually this is Hyper V on Windows 8). I can't remember windows 7 but do you have Hyper V installed?
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
snadge
ive been told on your sister forums (7) that Windows Virtual PC does not support 64-Bit clients At all...so i need to use VMware - will try it tonight after work
thnx
edit: check my specs now :)
    Windows 8.1 Pro x64
    Gigabyte H77
    LG Flatron 19"
    1440x900
    500Gb Seagate HDD
    Arctic Freezer Pro
    16Mbps
    Chrome
