Using Macrium Reflect
This is how I do it.
Works good.
First install it.
I have the paid Standard version:
Then create the recovery environment:
Then image all local drives.
I use maximum compression:
On usb:
It works good for me. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Nuccii
Canada
1,950
Good tutorial for those who want to use Macrium. Acronis is more to my liking though but that's me.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
Thank you. :)
It is just a quick tutorial.
Didn't cover everything.
Enough to get one started at making system images.
For example, when making the boot menu option you will be prompted to download the PE5 software.
About 400 or 500 MBs.
This is needed.
I made it so short because I figured people had enough common sense to follow any prompts that popped up. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Superfly
Developer
Cape Town
1,099
Good one David!
Hope those that have done store upgrades take note or they may get a nasty surprise should they need to reset/restore from recovery or something...:geek:
    PC-DOS v1.0
    IBM
    Intel 8088, 4.77MHz
    16K, 640K max
    What's that?
    Not quite
    80 X 24 text
Good one David!
I hope it helps someone. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
topgundcp
San Jose - California
2,847
Good one David!
It certainly will. And may I add to your tutorial:
Macrium is not just a good backup/Restore software that has never failed me. In the past, I used Acronis for a long time until I found out it modified the MBR and has installed services that I could not get rid of even when I did a complete uninstall and also the backup image might be good one day and the next day it went bad, it did not only happened to me but to several of my co workers so I dumped it.
Having said all that. Here's what I found in addition to be good for backup/restore (paid version only). You can also use it as a partition manager, you can move partitions around , resize, expand partition to the left etc... just using drag & drop
Here's an example how to re-arrange the partitions:
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Anyone can feel free to add to it.
The more information the better. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
mikeytg
Joisey
315
#8
Depending on your system you may not want to "image all local drives". My laptop has a conventional hard drive and a small SSD drive that caches frequently used stuff. Since there is no reason to image the SSD I only image the main HD.
To do this I use the "Image this disk" link under the main drive in the Reflect window.
    Windows 8.1 consumer 64 bit
    Acer Aspire M5 481PT-6644
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
SIW2
Team Member
5,360
#9
Yes, most of them are similar in overall cocept. I use a different one, Aomei ( very good free standard version available).
Image partitions/drives/system and file backup. Manual/scheduled. Clone partition/drive. Full/incremental/differential. Restore partition/drive/system/files from image. Resize partitions during restore.
Overall it offers more than any other free version. It is also small, fast, unintrusive and makes pe recovery media without needing a large download.
You might want to look at a couple and see what you like. E.G. Paragon free doesn't have as many features as Aomei, and it is a lot bigger, but it does have a couple of different features. It can exclude files/folders from images, which might be useful to you, or not.
Depends what you want.
    7/8/ubuntu/Linux Deepin
