Using Bitlocker and Symantec Encryption
jkility
Joined
Feb 7, 2015
Bristol
Hi all
bare with me on this, it may sound stupid and have a very simple answer.
I've got a laptop which I currently have Symantec Desktop Encryption installed with C:/ encrypted.
Personally not quite sure if the files it self on C:/ are encrypted or not (I'm able to access my laptop which has the drive encrypted, over the network from my desktop without any issues/error messages to say its encrypted etc)
This is where the possible stupidity comes in. Symantec current has the drive encrypted (Enter password before booting to Windows), but I was wondering if the data it self is encrypted and if not, would it be possible to do this within Symantec (Cant seem to find a way) if not, would Bitlocker be a solution to encrypting the data or will this cause confliction?
On the side as well, I know that Windows has an option to show folders/directories in a different color if they are encrypted, this option is enabled, but none of the directories are coloured, any idea how to get this to work?
Thanks in advance
Josh
    8.1 Pro
    AMD FX 8350
    8GB DDR3
    Radeon R7 200
    128GB Sandisk SSD
    256GB Crucial SSD
    1TB Western Digital
    Corsair CS750M
    Zalman Z11+
    Master Cooler
    Corsair Raptor K30
    N Trust Wireless
    37MBPS
    AVG
    Country Flag
    UK
theveterans
Joined
Sep 30, 2012
If it said encrypted, it really is. For example, someone detached the hard drive from your system and then inserted that to another computer to read the contents. Symantec will notify a password entry and if there's no recovery key, you won't be able to access it. It works like BitLocker To Go. BitLocker Drive Encryption doesn't need a password prompt if the drive is connected to the original motherboard and there's no changes to BIOS settings or updates AFAIK.
    Windows 8.1 Pro x64 with Media Center
    Tablet
    Surface Pro 3
    Core i5 4300U @ 1.9 GHz
    Surface Pro 3
    8092 MB DDR3-L 1.35 V SDRAM @ 1600 MHz
    Intel HD 4400 @ 200 MHz
    Realtek HD Audio
    Built-in 3:2 display
    2160 x 1440
    256 GB SSD + 128 GB micro SD
    36 Watt power brick
    Active
    On Screen Keyboard
    Surface pen
    300 / 20 TWC
    IE 11 Metro, IE 11 Desktop
    Country Flag
    USA
    State/Region Flag
    us california
crawfish
Joined
Mar 2, 2012
That's for Microsoft's Encrypting File System, which is unrelated to BitLocker.
jkility
Joined
Feb 7, 2015
Bristol
Great thanks very much, I've tried the encryption on my dekstop PC SSD and long story short I had to use partition magic ATA Secure Erase just to delete the encryption from the disk
So how can one get Microsofts encrypting file system?
    8.1 Pro
    AMD FX 8350
    8GB DDR3
    Radeon R7 200
    128GB Sandisk SSD
    256GB Crucial SSD
    1TB Western Digital
    Corsair CS750M
    Zalman Z11+
    Master Cooler
    Corsair Raptor K30
    N Trust Wireless
    37MBPS
    AVG
    Country Flag
    UK
