Using a spare SSD for Pagefile and caching
Hi all,
Quick question. I have a spare Agility 2 64GB SSD doing nothing so I'm wondering if I can use it as a pagefile drive for my OS drive which is also an SSD drive.
*NOTE*
All the threads I've read about this have all been about using the OS drive whether it be an SSD drive or HD for pagefiling. I want to use a SPARE SSD drive to pagefile FOR my OS drive.
Is this even possible and if so, how do I do it?
    WIN 8.1
    Self built custom
    Inter i7 3930K
    Asus P9x79 DELUXE
    6 x 4 Gb Kingston HyperX RAM triple channel 24GB total
    Gigabyte GTX 760 4GB x 2 in SLI
    Onboard Realtek 5.1
    BENQ XL2420T 120Hz Gaming monitor
    1 Mushkin 240gb (primary OS) plus a few other storage drives
    Cooler Master Silent Power 1000W
    Corsair Obsidian 800D
    Swiftech H320 closed loop water cooling system
    Logitech G510
    Razer Mamba 2012
    So fast I go to plaid quite often
    Eset Antivirus 7
1,883
Yes, it is possible.
The general advice is not to do it, since it can shorten the life of the SSD because the pagefile is written to often and SSDs have their limitations in regards to that.
But things have gotten better: Taking a Hard Look At SSD Write Endurance - Slashdot
It's for you to decide. I say better to make sure you have enough system RAM (8 GB is starting to get into the "a lot" zone for 64 bit OS - on a 32 bit OS, 4 is "a lot".)
I see you have 24 GB of RAM installed. The pagefile still does certain things, but will be used much less than a system with say 4 GB RAM.
If you do it, make sure TRIM command is active in Windows.
All you would need to do is tell Windows to set the page file to the drive, while deleting the current page file. Nothing difficult.
    7601.18247.x86fre.win7sp1
    Self-built Intel based
    Intel DQ965MT
    Hyundai 2 GB DDR2 @ 333 MHz
    Thermaltake 450W
    Logitech M510
    Optimum Online, fast for US
    Pale Moon
