USBPORT.sys - LatencyMon says I have problems.
evornoss
Hi guys,
I've been reading a lot about this USBPORT.sys problem, but have tried everything and still no luck.
I have the power savings set to Performance, have Cool 'N Quiet disabled and Performance Boost (Turbo Core) disabled aswell in BIOS.
My main problem is that I don't get full performace out of this GPU under games, specially under Battlefield 3 (also other games, most of them). GPU Usage stays from 40% to 70% no matter what settings (low-medium-high-ultra) or whats going on in the game, therefore I get below FPS that what I should for this card/resolution. I get dips to 40FPS when with this card, in that game, should never hit below 60FPS. It lags sometimes, its unnaceptable for this card. My CPU doesn't hit 80% so this is not a bottleneck case (at least thats what I've come to believe so far.)
I've tried everything, I even Overclocked my CPU to 4.0GHz and no change at all (Back to 3.7GHz [stock]). Did a fresh install of Windows 7 Pro 64bits, no luck either. Right now I installed Windows 8.1 Pro 64 Bits, all updates up to date. still the same. I was getting this USBPORT.sys problem on Windows 7 too, still here on Windows 8.1.. so that got me thinking.. maybe its not a CPU/GPU Problem.. maybe its this USBPORT.sys problem?
Here are some screenshot of after about 40mins playing BF3
Any help will be DEEPLY appreciated. I don't know what else to do, seriously.
    Custom Build
    Intel i7 4790k @ 4.4GHz
    ASRock Z97 Extreme6
    Kingston 8GB (2x4GB) DDR3 @ 1600MHz 9-9-9-27-36 @ 1.65v
    XFX R9 280X DD 3GB GDDR5
    Creative SoundBlaster X-Fi Titanium
    1680x1050
    Samsung SSD 840 Pro 128GB
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech Illuminated Keyboard
    Logitech G500
    5Mbps / 1Mbps
    External Western Digital 1TB HDD (via USB)
Anyone?
    Custom Build
    ASRock Z97 Extreme6
    1680x1050
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech G500
    5Mbps / 1Mbps
Bump?
    Custom Build
    ASRock Z97 Extreme6
    1680x1050
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech G500
    5Mbps / 1Mbps
Help?
    Custom Build
    ASRock Z97 Extreme6
    1680x1050
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech G500
    5Mbps / 1Mbps
I don't know what might be wrong, but are you running any USB audio devices, like a headset for the games? Is there any driver update for it?
What type of audio setup do you have, onboard audio and any driver updates for it?
If it happens in Windows 7 and Windows 8, you may need to look at your basic system. Perhaps the bios needs updating, as the utility suggests, or memory or hard drive problems.
Anything in the Event Viewer?
    Windows 8.1 x64
    Home Grown
    i7 3770K
    ASUS P8Z77 -v Pro, Z87-Expert
    16 G
    EVGA GTX 680 Classified (2)
    Kingston SSD 240 GB
Audio setup:
1x Creative SoundBlaster X-Fi Platinum, drivers up to date according to their website.
1x Logitech G930 Wireless Headset, drivers up to date according to Logitech's.
On board audio is disabled through BIOS.
I just changed (upgraded) my system. My system is now as follows:
CPU: Intel i7 4790K @ 4GHz
MOBO: ASRock Z97 Extreme6
rest of the hardware remains the same.
I am still getting problems according to LatencyMon (I think?), but this time around it tells me that everything is fine, although the last bar of the main screen is all the way up. I don't know if this is normal or not. This is what I got running LatencyMon for 39mins. Can you please tell me what to look for here in order to know if I am ok now or if I still have problems? I don't know which values are considered as normal or which are not, etc.
Any help will be greatly appreciated.
Main:
Stats
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:40:26 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: HOME
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: ASRock, Z97 Extreme6
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
RAM: 8146 MB total
CPU SPEED
Reported CPU speed: 3999.0 MHz
Measured CPU speed: 4608.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 502.418240
Average measured interrupt to process latency (µs): 2.826077
Highest measured interrupt to DPC latency (µs): 486.029470
Average measured interrupt to DPC latency (µs): 0.529623
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 433.553888
Driver with highest ISR routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.010649
Driver with highest ISR total time: portcls.sys - Port Class (Class Driver for Port/Miniport Devices), Microsoft Corporation
Total time spent in ISRs (%) 0.025886
ISR count (execution time <250 µs): 890274
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 1
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 471.517879
Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 0.012416
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0.056876
DPC count (execution time <250 µs): 8643849
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 15
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 10524
Hard pagefault count of hardest hit process: 2605
Highest hard pagefault resolution time (µs): 7565846.783946
Total time spent in hard pagefaults (%): 0.051953
Number of processes hit: 24
PER CPU DATA
CPU 0 Interrupt cycle time (s): 66.511354
CPU 0 ISR highest execution time (µs): 433.553888
CPU 0 ISR total execution time (s): 5.024030
CPU 0 ISR count: 890275
CPU 0 DPC highest execution time (µs): 471.517879
CPU 0 DPC total execution time (s): 9.794276
CPU 0 DPC count: 7726322
CPU 1 Interrupt cycle time (s): 34.150561
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 98.366092
CPU 1 DPC total execution time (s): 0.091597
CPU 1 DPC count: 41100
CPU 2 Interrupt cycle time (s): 30.381236
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 339.584896
CPU 2 DPC total execution time (s): 0.540244
CPU 2 DPC count: 539032
CPU 3 Interrupt cycle time (s): 40.960068
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 132.587147
CPU 3 DPC total execution time (s): 0.141745
CPU 3 DPC count: 39304
CPU 4 Interrupt cycle time (s): 26.497241
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 424.876969
CPU 4 DPC total execution time (s): 0.193683
CPU 4 DPC count: 132504
CPU 5 Interrupt cycle time (s): 38.273887
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 112.264316
CPU 5 DPC total execution time (s): 0.047397
CPU 5 DPC count: 26529
CPU 6 Interrupt cycle time (s): 26.754647
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 210.612653
CPU 6 DPC total execution time (s): 0.184125
CPU 6 DPC count: 114263
CPU 7 Interrupt cycle time (s): 39.449773
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 97.026507
CPU 7 DPC total execution time (s): 0.045505
CPU 7 DPC count: 24810
Processes:
Drivers:
CPUs:
    Custom Build
    ASRock Z97 Extreme6
    1680x1050
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech G500
    5Mbps / 1Mbps
The information you post would probably be very help for someone who had experience with that utility and what the numbers meant.
But I notice the Sound Card you are using is no longer available, so it may be older. I have not checked for its drivers, but you do have some from Creative that are for 8.1.
It is probably not relevant, but are you using a wireless mouse or keyboard...?
If I had a concern, as you do, I would test some things. First, disconnect the headset and connect a headset directly into the SoundBlaster. See if that helps, and if not, go back to the onboard audio to see if it might work better.
The headset appears to have some capabilities which might take extra time to implement, like voice morphing, so possibly it is just that or another feature causing the latency.
    Windows 8.1 x64
    Home Grown
    i7 3770K
    16 G
    Kingston SSD 240 GB
Thanks for your input.
Yes, this Soundcard is kinda old now, but still I have the latest drivers for it. Still better than most of the integrated sound solutions in the latest premium MOBOs IMHO.
Indeed, my Headset has voice morphing.
Maybe as you said, someone who is more familiar with LatencyMon can shed some light on this.
Thanks again :cool:
    Custom Build
    ASRock Z97 Extreme6
    1680x1050
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech G500
    5Mbps / 1Mbps
Your new system looks normal; It could be better but its within normal spiking on latency. Also don't really put much thought in the pagefaults they don't mean much. On your original setup I would have laid the blame on the logitech usb headset.
Also many games suffer from what you describe as low fps and low gpu/cpu usage, which one are you referring to?
    Windows 8.1 Pro x64
    Lily
    intel 4790k@4.7
    msi z97 mpower max ac
    16gb ripjaws x @2133
    evga 980ti sc+
    creative sbz
    dell u3011
    840 evo 250 & 9tb
    evga supernova 1000
    corsair 750d
    corsair h110
    logitech g710
    logitech g502
    cable@110/15
    firefox
    webroot
Hi there, how do you know this is between normal spiking? I would like to know that so I can learn.
I was refering to Battlefield 3, under multiplayer 64 players, NFS games, The Witcher 2, etc.. which all of them would drop very hard on FPS due to poor GPU usage. I got that resolved now, it was because of my graphics card (R9 280X 3GB) was causing a bottleneck to my previous AMD Phenom II X6 1100T, even when overclocked at 4.0GHz.
    Custom Build
    ASRock Z97 Extreme6
    1680x1050
    Corsair TX850W
    Zalman Z9 Plus
    Corsair H80i
    Logitech G500
    5Mbps / 1Mbps
Hi, I'm going by your pic where even though it spikes to 500+ its still says its suitable for audio work. So I'm guessing its only spiking above 100 every few secs. But many things can affect latency; anything from your drivers, power saving features, enabled devices and even the motherboard itself can have an effect on latency.
Glad your issues are resolved and enjoy the sweet upgrade:)
    Windows 8.1 Pro x64
    Lily
    intel 4790k@4.7
    evga 980ti sc+
    creative sbz
    dell u3011
    840 evo 250 & 9tb
    evga supernova 1000
    corsair 750d
    corsair h110
    logitech g710
    logitech g502
    cable@110/15
    firefox
    webroot
